Results 1 to 15 of 25
    Article: Propeller Test: Sharrow vs. Standard Prop on Robalo R302
    May 2001
    Scottsboro Alabama
    What is the conventional prop?
    May 2022
    Maine
    Conventional Prop
    Quote Originally Posted by stan merck View Post
    The stainless steel 15.25” x 19 was mentioned in the beginning of the article 3 blade I presume. I'm guessing for copyright issues the model and manufacturer was left out.
    Jul 2007
    Delray Beach
    Was this a paid ad? All the Sharrowtests so far are paid ads?
    Feb 2011
    HUDSON, FLORIDA
    Its trickery, b.s. dont believe it. a play with words. 2 boats going 25 mph, how can 1 go 100 miles further?
    Feb 2022
    Quote Originally Posted by KIRCHNER View Post
    "The Sharrow Propeller gets more miles per gallon (MPG) than the conventional props at all speeds, except at WOT.....we see that at 25.4 MPH, the R302 can travel 109 miles (29%) farther than it can with conventional props."
    This is not a play on words, It is about efficiency at the mentioned speed in the tests they did. When you use less fuel, you get more MPG. The conventional prop took an additional approximate 700 rpms to do 25 MPR, you will not go as far burning more fuel.
    Sep 2021
    US
    The conventional propeller requires an additional 700 RPMs to achieve 25 MPR. Using it will result in burning more fuel and traveling less distance.
    prayer warrior
    Feb 2011
    HUDSON, FLORIDA
    ITS such B S. LISTEN 2 boats going 25 mph, one goes 75 miles further???? so its going 100 mph. go buy one let me know how much money you wasted
    Feb 2011
    HUDSON, FLORIDA
    it shows at 3500 rpm std prop, the test boat only goes 20 mph. when pigs fly. maybe 10 people in the stern and full trim
  10. Likes David - WI liked this post
  11. #10
    Jan 2024
    Florida, United States
    Thanks for doing that test. It is so helpful! condensing water heater repair denver
  12. #11
    May 2024
    Los Angeles
    Beautiful post, I absolutely LOVED IT!!!
    basement waterproofing columbus
  13. #12
    Sep 2021
    US
    Castle Drywall in Winston Salem
    The stainless steel 15.25” x 19” mentioned at the beginning of the article sounds like a fascinating piece of equipment, particularly the 3-blade design that was referenced. Given the specificity and the apparent importance of this item, it's intriguing that the article chose to omit the model and manufacturer details.
  14. #13
    May 2001
    Scottsboro Alabama
    All these boat test.com are paid ads, not real tests.
  15. #14
    Jun 2024
    Australia
    Thumbs up
    Quote Originally Posted by davidson02 View Post
    prayer warrior
    How does the increased fuel consumption with the conventional propeller affect the boat's operational costs over time? Additionally, what are the long-term benefits of using the Sharrow prop in terms of fuel savings and travel efficiency?
    MotorGlass
  16. #15
    A spammer quoting a spammer... priceless.
  1. Sharrow Prop testing
    By TwzteD in forum General Boating Discussion
    Last Post: 10-19-2019, 07:18 AM
  2. A better look at that funky new Sharrow prop
    By home made tunnel in forum General Boating Discussion
    Last Post: 05-30-2019, 10:30 AM
  3. Photos: The VERY unusual Sharrow Propeller
    Last Post: 05-14-2019, 04:10 PM
