Results 241 to 255 of 263
04-29-2024, 04:04 PM #241
floor board in. Seat mounted. Cockpit done except for steering stuff.......
05-01-2024, 03:20 PM #242
So this boat was originally raced with no rear cowl, just a tonneau cover snapped in place. somewhere along the line it did get a rear cowl made from a sheet of fiberglass. Here i have installed the old rear cowl to get an idea how tall it was and the length. I plan to fabricate a new rear cowl using 3mm Okumi ply. enjoy.....
05-01-2024, 06:15 PM #2436000 RPM
- Nov 2006
- 1,511
- 14
- 130
- 70
- 630
- 35 Post(s)
Looks a $1000 better than a snap on tonneau cover!
Tom Smyth liked this post
05-01-2024, 08:50 PM #2445000 RPM
- Mar 2016
- cincinnati, ohio
- 673
- 147
- 33
- 280
- 192
Are you going to add a raised piece or hump at the rear to kind of blend in that tall black motor??
05-01-2024, 09:39 PM #2456000 RPM
- Nov 2006
- 1,511
- 14
- 130
- 70
- 630
- 35 Post(s)
I tried a "hump" on a Glastron Moli once. It looked dumb. You can see the relief Tom has cut for trim out position for the Merc. I'm still trying to imagine this boat with twin 150's bolted on at one time.
05-02-2024, 05:14 AM #246
SlingShot liked this post
05-03-2024, 08:11 AM #2475000 RPM
- Mar 2016
- cincinnati, ohio
- 673
- 147
- 33
- 280
- 192
So how do you think that beast ran with two different engines??? Was the 140 a power ported engine, would they have had a different power curve, how would you set up something like that???
05-03-2024, 11:18 AM #248
05-04-2024, 01:42 PM #2496000 RPM
- Nov 2006
- 1,511
- 14
- 130
- 70
- 630
- 35 Post(s)
05-05-2024, 08:03 AM #250
Activity on a couple of tasks. Got the steering plates in and test fitted them. Deciding whether to center the Pulley or the vertical pivot axis at the same height and distance as the motor hinge pin. Do not want to slacken or tighten the steering cable when at different trim angles.
Second started layout on the rear cowl. Matched a couple boards to the same outline as the top edge of the cockpit. then cut the first piece of three internal support members. A bit too high to start. Work will continue this week. Plan to use 3mm Okumi for the rear cowling.
05-06-2024, 03:00 PM #251
second iteration of wing plates received. After a few quick measurements and a trip to the bending machine, we should have the pulley perfectly aligned with the centerline of the motor hinge pin. the exceptional WIDE cockpit on this boat presented a few challenges but we have cracked that nut i think.
05-07-2024, 09:47 AM #2526000 RPM
- Nov 2006
- 1,511
- 14
- 130
- 70
- 630
- 35 Post(s)
05-08-2024, 02:45 PM #253
Rear cowl bulkheads cut and fitted to the cockpit. Next is lightening them and making the sockets for the cowl to fit into.
05-13-2024, 03:04 PM #254
So the rear cowling frame is done and fitted to the cockpit. Made the little bracket that it sits in to hold it in proper position. Tried to bend a scrap ply piece of 3mm over it. Damn that stuff wont bend. Going back to 2 mm for the cowling. the attached pic shows how well a scrap piece of 2mm i had left from the front cowling bends into shape. Probably put a layer of mat and glass on the inside though to stiffen it up a bit when its all done.
05-14-2024, 06:42 PM #2556000 RPM
- Nov 2006
- 1,511
- 14
- 130
- 70
- 630
- 35 Post(s)
How do you plan to keep it in? Jeep hood rubber snubbers? Pins?
18’ Baker Tunnel Restoration
By Pilotryan in forum Boat Build-Ups and RestorationsReplies: 8Last Post: 01-11-2022, 01:08 PM -
Allison XST18 Restoration Complete
By freeebird in forum General Boating DiscussionReplies: 7Last Post: 07-14-2021, 08:03 PM -
Phantom 25 - 30 years ol getting complete restoration
By Toffen in forum General Boating DiscussionReplies: 16Last Post: 05-23-2015, 11:56 AM -
Engine height on DelCraft Wooden Tunnel Hull:
By Marchettih2o in forum Props, Setup, and RiggingReplies: 7Last Post: 06-25-2010, 12:11 AM -
14' DelCraft Tunnel & 850XS W/SSM:
By Marchettih2o in forum Props, Setup, and RiggingReplies: 4Last Post: 10-22-2007, 09:23 AM
