Results 226 to 240 of 310
04-14-2024, 10:30 AM #226
no idea on the nose cone. It ws already on the lower when i got it. This boat set the Sport J APBA record in 1970 at 77 MPH and change with a 135 Merc. Bob Holloway was the owner / driver for that .
NICE PAIR liked this post
04-14-2024, 06:09 PM #227
6000 RPM
- Nov 2006
- 1,759
- 18
- 183
- 86
- 785
- 45 Post(s)
Sport J OEM Rules
Pics #1 and #4............I never did get a straight answer from all my Sport J inspectors on whether the tower wrap cowl had to be in place where the steering bars were attached? I heard these wild tales about how the engine could draw more air with the wrap cowl not being there?
04-15-2024, 02:50 PM #228
started poking holes in the dash. Trying to use only vintage hardware....
04-17-2024, 04:38 PM #229
and the rigging continues SLOWLY with the one and a 1/4 arm man........
04-17-2024, 04:46 PM #230
5000 RPM
- Mar 2016
- cincinnati, ohio
- 696
- 151
- 36
- 287
- 205
What's the quarter arm???
04-17-2024, 06:42 PM #231
Had left thumb surgery last week. Sucks to get old….
04-18-2024, 10:17 AM #232
5000 RPM
- Mar 2016
- cincinnati, ohio
- 696
- 151
- 36
- 287
- 205
Not for the weak!!
04-23-2024, 03:52 PM #233
progress is slow with left hand still recovering from surgery and in a hard splint. BUT managed to get the mechanical trim indicator mounted and cable installed. Also the floor board that will support the seat, gas tank, battery and trim pump cut, fit checked and starting the process of 3 or 4 coats of UV resistant epoxy on it.
going with the floor board to eliminate bolting directly to the tunnel bottom as was originally done. Not looking for SPEED. want this boat to last another 50 years...
04-23-2024, 04:09 PM #234
also got the four switch electrical panel drilled and sent out for powder coat.
motexas liked this post
04-24-2024, 08:40 AM #235
6000 RPM
- Nov 2006
- 1,759
- 18
- 183
- 86
- 785
- 45 Post(s)
Nothing like a basic cable trim readout. Nydahls were the best (and still are). I never really knew what the numbers meant (degrees?). I used 1/4 marks instead.
Tom Smyth liked this post
04-26-2024, 04:07 PM #236
A little more progress today. Main wiring harness in and main switch panel installed. Hole drilled for the kill switch. Control box with the gear shift cable in place. It will just fit in the beside the bucket seat...
04-28-2024, 04:13 PM #237
so the cockpit dash is complete. Kill switch is in, tach in , everything wired........progress towards the first engine fire up in a few weeks hopefully. Power trim arrangement set and hoses measured. They should be ordered this week. Battery switch installed. Just about done except for steering stuff.........
04-28-2024, 04:14 PM #238
Oh and building the rear cowling. Hope to start that in a week or two.....
89LASER liked this post
04-29-2024, 08:42 AM #239
6000 RPM
- Nov 2006
- 1,759
- 18
- 183
- 86
- 785
- 45 Post(s)
04-29-2024, 09:41 AM #240
18’ Baker Tunnel Restoration
By Pilotryan in forum Boat Build-Ups and RestorationsReplies: 8Last Post: 01-11-2022, 01:08 PM -
Allison XST18 Restoration Complete
By freeebird in forum General Boating DiscussionReplies: 7Last Post: 07-14-2021, 08:03 PM -
Phantom 25 - 30 years ol getting complete restoration
By Toffen in forum General Boating DiscussionReplies: 16Last Post: 05-23-2015, 11:56 AM -
Engine height on DelCraft Wooden Tunnel Hull:
By Marchettih2o in forum Props, Setup, and RiggingReplies: 7Last Post: 06-25-2010, 12:11 AM -
14' DelCraft Tunnel & 850XS W/SSM:
By Marchettih2o in forum Props, Setup, and RiggingReplies: 4Last Post: 10-22-2007, 09:23 AM
