Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 75
  1. #31
    replacing all bunk supports
  2. Likes 89LASER liked this post
  3. #32
    installing BayStar hydraulic tilt steering
  4. Likes 89LASER liked this post
  5. #33
    Attached Thumbnails Attached Thumbnails 20230622_082524.jpg   20230622_082524.jpg
  6. Likes 89LASER liked this post
  7. #34
    the Yamaha controls came in ..
  8. Likes 89LASER liked this post
  9. #35
    when in wide-open throttle position, the length of control with the base is 11.75 inches ...
  10. Likes 89LASER liked this post
  11. #36
    but the console only allows me 9 inches ..
  12. #37
    I simply adjusted the location of the handle without the need to do fiberglass work now shortening the handles.
  13. Likes 89LASER liked this post
  14. #38
    Lindenhurst, NY
    What if you put a small wedge block of teak under the control box to pitch it slightly up in the front? The old whalers had teak on them.
  15. Thanks noli thanked for this post
    Likes noli liked this post
  16. #39
    The great corn desert of Iowa
    Don’t forget you also need room for your hand on top of the throttle.
    1971 Sidewinder 14 SS w Johnson 90 v-4
    1959 Texas Maid Falcon w Mercury Mark 35A
    1981 Sylvan Sportster w Johnson 85 v-4
    2006 Harris pontoon with a Yamaha 90
    1969 Sunfish sailboat
  17. Thanks noli thanked for this post
  18. #40
    yuup, removed the throttle handle, moved backwards (from normal upright position) 1 notch ... throttle has plenty of room now for wide-open position
  19. Likes 89LASER liked this post
  20. #41
    embedding stainless Tee-nut into flooring to hold the battery tray. will be completely sealed from the foam core in a bed of thickened epoxy
  21. Likes 89LASER liked this post
  22. #42
  23. Likes 89LASER liked this post
  24. #43
    embed battery-tray bolts into flooring using epoxy resin and fillers
  25. Likes 89LASER liked this post
  26. #44
    examining the plywood coring shows bone-dry wood and I want to keep it that way
    using screws and marine caulking will introduce water entry into flooring
  27. Likes 89LASER liked this post
  28. #45
    about to glass in the stainless battery tray bolts in a bed of resin
    fitting the battery tray
  1. Boston Whaler 13
    By nelsoncat in forum General Boating Discussion
    Last Post: 09-29-2011, 09:05 PM
  2. 13 Boston Whaler pad???
    By ecg101 in forum Technical Discussion
    Last Post: 12-31-2008, 05:47 PM
  3. My winter project, 1965 Whaler
    By blkmtrfan in forum General Boating Discussion
    Last Post: 07-30-2007, 08:23 AM
