ID:	530842Click image for larger version.
ID:	530843Click image for larger version.
ID:	530844Click image for larger version.
Name:	ELK HUNTING 120.jpg
Clean boat original stringers and transom in great shape. Trailer very nice. Full cover. Has tons of nice parts. Had the engine rebuilt about 20 hours ago. Block re-zinced, New 260 small rods, SPS bolts HIPO 260 bearings, Wizard 2 ring pistons TIN rings, milled heads .075 gaskets Factor 260 reeds, External Brucato ACU Lighten and balanced fly wheel , also big bearing 260. It has a 20" off shore mid and a sportsmaster lower. Last time out ran fine. Last compression check was 135-138. HERE IS THE BAD Power head came loose stripped out and broke a couple of bolts. Dowel pins are wobbled out. Have many more pictures on my phone. Price for everything is $20,000 614-496-4506
