Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
    ...the early vertical reed 200's ran really well. would like to own them. let me know if you decide to sell...
  2. #17
    Mar 2022
    Lake Travis Texas
    I wouldn't be too quick to change over to more power. Sure more power is sweet but, There is something to be said about a nice running carb engine. It fired up for you after all those years and it is easy to work on and maintain.
    How about sharing pix of the rest of the boat?
    Jim
  3. #18
    TX......somewhere?
    S&F doesn't have enough bandwidth to cover what will and will not work with tha V6.. best ta jus post a question or two at a time and you will get an answer pretty quick on here.. sounds like ya gotta case of tha sickness... welcome.
    they are both '78 200 2.4's..
    if ya add a "0" as tha first number in that type serial number it will pull up on most sites.... they incorporated that to all numbers when tha first "0D" series came out seems like.......... i don't remember any 0A, 0B, or 0C's till that happened.. they were jus A, B, or C then tha number............ was a long time ago.
  5. Thanks Cheifjunk thanked for this post
  6. #20
    Apr 2023
    Long island, NY
    Quote Originally Posted by Cheifjunk View Post
    im wondering if you guys can help me identify 2 older merc outboards i have. serial numbers are 5090080 and 5090081. i cant find anything on them and mercury had nothing. i think 1980 225s?Attachment 528012
    From process of elimination, they are 1978 2.4 200's. The Mercury V6 came out in 1976 starting with serial number 4301235 as a 3 1/8" bore 2.0L 175HP. It remained a 2.0L until serial number 6618750. So, it cannot be a 175. In 1978 the 2.4 3 3/8 bore 200HP came out starting with serial number 4839034. The 225HP 2.4 came out in 1980, but it started with serial number 5615282. your serial number is too low to be a 225Hp.
  7. #21
    TX......somewhere?
    Quote Originally Posted by skialot2 View Post
    see post #20.. "they are both '78 200 2.4's".. no elimination necessary..................
  8. #22
    Apr 2023
    Long island, NY
    Post # 20 is my post.
  9. #23
    Nov 2023
    Tacoma wa
    I really appreciate the lookout from everyone. This has really helped a ton
  10. #24
    Jan 2020
    Pittsburg, Ca
    Badass to run the steering through the cowl like that. I like it.
  11. Likes Cheifjunk, tlwjkw liked this post
  12. #25
    TX......somewhere?
    try #19 then............ besides being old guess i'm gettin blind toooooooooo.
    i'm still amazed with jus how clean those two "OLD" first gen. powerheads are
  13. Likes 25two.stroke liked this post
  14. #26
    Nov 2023
    Tacoma wa
    I really appreciate that!
  1. Help! early serial number identify
    By Cheifjunk in forum Outboard and Racing History
    Last Post: 12-21-2023, 07:43 PM
  2. Bracket serial number different than Block number
    By NZ Sidewinder in forum Technical Discussion
    Last Post: 04-20-2021, 05:19 AM
  3. Help: Identify this mariner - no serial number
    By Amott1989 in forum Technical Discussion
    Last Post: 02-01-2021, 08:07 PM
  4. Help identify Merc block by serial number
    By FlatSleek in forum Technical Discussion
    Last Post: 07-14-2016, 06:29 AM
  5. Can anyone help me identify this motor by serial #?
    By dma251 in forum Technical Discussion
    Last Post: 09-20-2005, 02:52 PM
