Results 1 to 6 of 6
    Cudjoe Key FL
    Ignition Coil Costs
    Coil part #300-8M0077471 from Mercury is $188 and the same coil from DB Electrical is $45.
    My question is should I bite the bullet and buy the Merc coil or go with the less expensive one? Secondly, if one went bad are the others far behind like so many parts tend to fail relatively at the same time. Motor is a 300xs with 300hrs on it. Thank for your opinions.
    I have used DB for some stuff, coils included. I have had no problems. Good place. You may also be able to get some used merc oem coils from E-bay for a lot less. I have done that too. One bad coil is not an indicator of the others failing. Merc is nuts with it's pricing. I used to be a die hard fan of only merc parts. No more!
  3. Likes sonicss33 liked this post
    Dec 2019
    Spring Lake MI
    I would get it from here so you know its a high quality unit. https://www.bmotorsports.com/shop/pr...qk3d1jdkvc4r97
    TJ @ Baker Engineering
    Tuff 24 300xs
    Tuff 16 90 Yammie
    3.75@199mph with LSX power!!!
  5. Likes XstreamVking liked this post
    That's great info hellbents!
    Feb 2006
    Formerly Central WI/LOTO Currently PHX AZ
    Make sure you know if it's a small coil or big coil engine, the coil characterizations are different...you didn't state the year of your XS, and there were at least 3 different coil p/n's over the years. Just make sure they match and you'll be fine. Connectors are the same, so don't go by that.
    A problem is only a problem when viewed as a problem...
  8. Thanks pcrussell50 thanked for this post
    Likes pcrussell50, sonicss33 liked this post
    Cudjoe Key FL
    2007 BTW. Thanks Johnnie. Sean helped diagnose it.
  1. 300xs Ignition Coil | Coil Harness | Harness | Power Head Studs & Bolts.....
    By Pachanga_rick in forum Misc. Parts and Accessories
    Last Post: 08-31-2018, 02:35 PM
  2. Mercury Ignition Coil Suggestions???
    By kjdoo4 in forum Technical Discussion
    Last Post: 08-12-2018, 09:08 AM
  3. Ignition coil hardware
    By FORBESAUTO in forum Parts Wanted
    Last Post: 04-09-2018, 05:16 PM
  4. ignition coil test?
    By stvhelm in forum Technical Discussion
    Last Post: 08-31-2003, 09:59 AM
