Results 1 to 12 of 12
    Aug 2013
    Paducah
    260 on 2 piece plate
    I have a 260 powerhead and 2-225 promax’s. One is on the boat, the other is a spare. I want to put 260 power head on my spare. I have looked everywhere and cant find info on mounting a 260 on a 2 piece plate. I have found info on modifying one piece plate to run poppet but nothing on running a non poppet engine on 2 piece. Does anyone know if I can put the 260 on a 2 piece plate? Tia
    Aug 2023
    Plover Wisconsin
    Look at my thread since I'm figuring out same thing. It might help you. would be happy to talk to ya on the phone as well to go over all I've learned from the great people on here about this issue just message me.
    https://www.screamandfly.com/showthr...nd-overheating
    TX......somewhere?
    don't think there is any difference as for tha poppet/block part.. you should be able ta compare tha two blocks.. think tha only difference is with tha plate/plates when it comes ta poppet or no poppet..... thats one of several things i've never done... tha nick motor on a two piece...
    Aug 2023
    Plover Wisconsin
    Since it's not machined for a poppet valve you have to custom fit one into it to seal properly so you get good water pressure. Also have to add tstats as well. The 2 plates are different for water flow and the 2 piece allows to much water to flow to lower unit is the main issue. I'm no expert just learning from pros on here for same issue.
  5. Likes NICE PAIR liked this post
    TX......somewhere?
    i would double check tha size of tha openin' where tha grommet will go jus in case since its a 2.5 block... its a little different from what tha Bug was dealin' with.... may not need ta do anything to it... jmo.
    Aug 2013
    Paducah
    I understand. Really should just get one piece plate and be done with it. Mercury as far as I know put all 260’s on one piece plate for a reason. I don’t want to modify my plates I have since I would put my 225 back on it and would create issues with that.
  8. Likes NICE PAIR, Mrzip liked this post
    TX......somewhere?
    Quote Originally Posted by Joeys View Post
    that would be best and easiest... you're right about tha blocks.. ALL tha high performance (other than tha PM) came with tha one piece, even tha HP chrome 2.4's.... its tha heat and cool process thats different with tha chrome/nic and aluminum temps rise and fall completely different from tha steel sleeve motor...
  10. Likes NICE PAIR, Mrzip liked this post
    Be very careful, I believe I understood the high perf (260) needs a lot of water and it is tuff to get with a 2 piece and thermostats/pop-off. Again, be Careful you're messing with stuff thats becoming rare and expensive. Good Luck.
  12. Likes Joeys liked this post
  13. #9
    Aug 2006
    GA
    Get a 1 Piece Plate !
  14. Likes pkstv, NICE PAIR liked this post
  15. #10
    Moline,Ill
    is gone
  16. Likes David - WI, tlwjkw, NICE PAIR liked this post
  17. #11
    Aug 2009
    mpls,mn
    2 piece steel bore,,one piece nic/chrome bore.
    https://biggerhammer.net/mercury/
  18. Likes NICE PAIR liked this post
  19. #12
    Aug 2009
    mpls,mn
    Quote Originally Posted by scott reierson View Post
    Thanks Jerry
    Not jerry bro.
  1. Steering plate for 2.5 2 piece exhaust plate
    By 2.5-21 in forum Parts Wanted
    Last Post: 10-15-2013, 03:18 PM
  2. 2 piece exhaust plate vs 1 piece
    By tcrabtree in forum Technical Discussion
    Last Post: 09-01-2009, 10:48 AM
