Results 1 to 8 of 8
    Aug 2023
    Plover Wisconsin
    Timing arm sticky not going to full timing
    I noticed today after I disconnected my throttle cable to check all the linkages that the timing arm wasn’t going to the stop when wide open? I lubed it by the stater and it helped but it’s almost like it needs a spring added to it to go to the stop. When I hit throttle quickly it will go to stop but if I slowly apply throttle it stops a 1/4” to 1/8” short and was worse before lubing it. Do I need to remove flywheel to grease it or is something else going on? I could maybe add small return spring to help it?
    Jan 2020
    Pittsburg, Ca
    The spring inside the throttle arm itself is dirty or wore out
  3. Likes NICE PAIR, David - WI liked this post
    Jun 2009
    Bristol, Connecticut
    check to see if the trigger rod is hitting one of the 4 stator screws, i had to cut one of mine short for the arm to get to full timing
  5. Likes David - WI, Baker343 liked this post
    Apr 2023
    Long island, NY
    Make sure the wires from the timer base aren't pulling when you open the throttle.
  7. Thanks pcrussell50 thanked for this post
    Likes pcrussell50 liked this post
    Aug 2023
    Plover Wisconsin
    Quote Originally Posted by skialot2 View Post
    Did look at the wires and look ok and able to be moved. The spring might be the culprit of concern. Seems like if it had just a bit more spring would handle issue.
    Dec 2001
    The black sheat that covers the wire gets non fexable with age......cut some of it so it moves better......
  10. Thanks pcrussell50 thanked for this post
    Likes skialot2, pcrussell50 liked this post
  11. #7
    Aug 2023
    Plover Wisconsin
    The black sheath that covers the wire gets non flexible with age......cut some of it so it moves better......
    I thought this might also help when I looked at that part right where it comes out from under the flywheel. Thanks great suggestion will do.
  12. #8
    Apr 2021
    sacramento
    i got same problem, among others,not fun anymore
  1. Optimax Max Timing / Idle Timing
    By InjectorService in forum Technical Discussion
    Last Post: 08-04-2023, 10:48 AM
  2. Idle timing? and max timing?on a Merc 50hp
    By Keaten in forum Technical Discussion
    Last Post: 12-30-2021, 11:09 PM
  3. Replies: 19
    Last Post: 09-09-2015, 07:56 PM
  4. Yamaha Tech: Yamaha V6 timing base and full advance
    By 225XCL in forum Technical Discussion
    Last Post: 03-02-2015, 11:51 PM
  5. Yamaha Tech: Checking full advance timing without dying
    By Mr. Demeanor in forum Technical Discussion
    Last Post: 02-24-2010, 10:24 AM
