Results 1 to 13 of 13
Thread: 2.5 200 F Block
    Jul 2018
    Jackson mo
    2.5 200 F Block
    Recently bought a v-king that has a 2.5l 200 F engine on it. I used to mess with some 2.4l stuff back in the day and cant find any info on the F mota. Is it a good platform to start with? How does it compare to the FF? I am wanting to get some more power out of it. Any help would be appreciated.
    Jun 2018
    Floating around
    IIRC the single F is the 1991 7 petal steel sleeve mota. One year only model. Regardless any 2.5L 200 is a fantastic platform and more favorable than the 2.4 stuff
  3. Likes Cblyzes, Mrzip liked this post
    Jan 2020
    Pittsburg, Ca
    https://www.screamandfly.com/showthr...block-id/page3
    Read through all pages of that. I don't believe that the singe F stamp is only a 200 7 petal like the famed diagram shows.
    I have seen multiple F blocks that are factory unmolested and 5 petal front. Particularly in the 2000s and newer. The F/FF/EE are always 200hp blocks which are a good platform to start with.
    Jul 2018
    Jackson mo
    It is a 91 model. The heads look different than all of the other 2.5 that I have seen. I had a finger ported 2.4 that I had 6 2 bbl carbs on that ran pretty good. Stiil have the intake for the 6 deuces just was trying to see what the deal was for the motor I have. It runs pretty good on boat. I have seen 86 with 26 chopper out of it but need to get some stuff tightened up before i just hold it to the floor. Thought about maybe a Nik 245 if I can find one for a base and port from there. Appreciate the input.
    Jan 2020
    Pittsburg, Ca
    If its 91 then its a 7 petal. Good motor for light hull imo.
  7. Likes Cblyzes, gmorgan liked this post
    Baton Rouge, La
    I've had both on the same hull. I would start with the FF if I had a choice. It would cost plenty to make the exhaust chest of the F look and perform like the FF. Mike
    Cheaters never Win !!!
    Jun 2018
    Floating around
    Does the F share the same chest as the EE?
    May 2013
    Huntiington Beach Ca
    Yes, the F and EE are the same chest cut. And the 91 F had bottom guided rods.
    Freshen it up and run it.
  11. Thanks LakeFever thanked for this post
    Likes LakeFever liked this post
    May 2013
    I believe stock heads back in 91 were 40 or 42cc heads.
    Throw some new rings, reeds and 36cc heads and let her rip
    Jun 2014
    United States
    That block can be modified to turn 11,000 rpms on an Allison Drag boat. So whatever you want, it’s there for the taking.
  14. Likes Mrzip, David - WI liked this post
    Aug 2006
    GA
    Cblyzes.. What Kind Hull You Running ?
  16. #12
    Jul 2018
    Jackson mo
    Its on a vking yt
  17. Likes Mrzip liked this post
  18. #13
    mid ga
    Quote Originally Posted by Cblyzes View Post
    Not absolutely sure this is correct
  1. Replies: 51
    Last Post: 06-18-2019, 03:25 PM
  2. Replies: 3
    Last Post: 02-11-2019, 09:52 AM
  3. Replies: 2
    Last Post: 03-11-2016, 08:07 PM
  4. Replies: 5
    Last Post: 08-10-2015, 04:25 PM
