Page 3 of 3 FirstFirst 1 2 3
Results 31 to 44 of 44
  1. #31
    Jul 2022
    Idaho
    Any update on this build???
  2. #32
    Jun 2014
    Petawawa, ON
    At the moment we are getting dicked around by freight companies. But that should be sorted out by tomorrow.
  3. Likes InjectorService liked this post
  4. #33
    Nov 2019
    Canada
    I received a care package from Derek today, finally after fighting with shipping companies for a couple of weeks. Hopefully this means we can continue with the project as planned!
    www.InjectorService.com
    Call/Text - 204-326-0390
  5. Likes mistah_max, 89LASER liked this post
  6. #34
    Nov 2019
    Canada
    Got the paint stripped off the lower unit, off to polishing. I'm not sure how it will turn out as it is very pitted, but we're going to try!
    Midsection was also dropped off for powdercoat so should see that back soon. Once I get it Ill bring the trim unit & lower pan for paint match. Then bronze bushings, reassemble. By that time the block should be back from machining, reassemble. Id say mid July would be a good time for a first fire.
  7. Likes 89LASER, OnPad liked this post
  8. #35
    Nov 2019
    Canada
    Small update again. Powdercoater messed up, painter messed up. So more delays but some stuff is assembled. Powerhead is together. Bronze bushings are in, should be some big progress next week.
  9. Likes 89LASER, mistah_max, X-DEWAR-X liked this post
  10. #36
    Nov 2019
    Canada
    HERE IT IS! What you've all been waiting for! The first ever 15" Yamaha SHO!
  11. #37
    Jul 2022
    Idaho
    What kind of hull is this going on? I can't wait to see it hit some impressive numbers. This is huge for the Yamaha sho platform.
  12. Likes Greg G, X-DEWAR-X liked this post
  13. #38
    East Wallyworld Vt
    That will be a fun ride.
    Regards,
    Charlie North
    If it ain't broke, modify it.
    87 Glastron CVX20 Hull
  14. #39
    Jul 2009
    gatineau qc, canada
    imo this should be gettin way more attention then it is!
    this is one of my 'go to' threads when i log on here.
    can wait to see it done!
    1998 charger stv. 225 promax. -sold-
    1993 22 talon. 2016 yamaha 200 SHO, nizpro tuned
  15. Likes aj06bolt12r, X-DEWAR-X liked this post
  16. #40
    Jun 2002
    Winter Haven Fl.
    I know it is a niche market but Yamaha and Merc need to make us a 15 inch motor. Eventually all the old motors we use will die off.
  17. Likes FAST RALLY SPORT, 724Bravo liked this post
  18. #41
    Jul 2023
    N.OC & LHC
    Awesome work there Eh!!
    I'm a SHO fan and a Yamaha OB guy for that matter, I'm in my 60's and have run all of the mfg's and Yamaha has always been my first choice.
    What you have transformed this SHO to is just amazing and I the rest of us can't wait to see this baby run.
    I have a new 22' Liberator hull on order to be rigged by myself and the standard recommended motor is a Mercury 300r, I would love to throw a tuned 250SHO with a nose cone on it but have reservations about the performance as far as numbers go.
    Has anyone that has installed the be it Bob's or Nizpro nose cone seen any great performance increases out of it ?
    I did find one thread in a Yamaha Bass Boat forum and there was no top speed gain but did see better cooling water flow and temps.
    Anyway, keep up the great work, and Thanks
  19. #42
    Jun 2014
    Petawawa, ON
    Quote Originally Posted by 724Bravo View Post
    You have a DM re: nizpro cones and numbers.
  20. #43
    May 2019
    Kawartha Lakes ON Canada
    Derek coned the SHO gearcase on my Venom for me last fall. I gained over 10MPH on topend. Overall stability and drivability of the boat were drastically increased as well.
  21. Likes Instigator, canuckr, 89LASER, Greg G liked this post
  22. #44
    Jul 2022
    Idaho
    There are a couple Yamaha SHO Liberators out there, but nobody has really documented the performance difference VS a 300R. I would love to see someone take on that job. And then supercharge the SHO with the new 525hp tune and then see what it can really do.
  1. Short shaft 50 hp Yamaha motor
    By yellowfever in forum Outboard Engines
    Last Post: 02-25-2018, 07:57 PM
  2. Want to build a Short Shaft V4 Looper
    By ttopping in forum Parts Wanted
    Last Post: 12-20-2017, 07:32 PM
  3. Short shaft 40/50 Yamaha mid
    By scc82 in forum Parts Wanted
    Last Post: 04-22-2014, 04:23 AM
  4. Yamaha long shaft to short shaft
    By MarkMuzzy in forum Technical Discussion
    Last Post: 02-19-2010, 08:55 AM
