Results 1 to 8 of 8
    Apr 2023
    Long island, NY
    1989 Checkmate Spectra resto
    I bought a 1989 Spectra 171 Project in February.
    Somebody had painted over the sunburnt and faded gelcoat with what almost looked like bedliner. I used Fiberglass paint stripper to remove it section by section.
ID:	520200Click image for larger version.
ID:	520201Click image for larger version.
    Then I used a DA sander with 320 grit and sanded deep into the sunburnt red gelcoat until the crazing was gone. I can't believe how thick it is... was. Then I wet sanded the whole boat with 600 then 1000 then 1200 then 1500. Then I used old school compound and wax and got a mirror shine.
ID:	520203Click image for larger version.
    Then I found a soft spot in the floor behind the driver's seat. Went to fix the floor and boy did that snowball. Removed the floor, found rot in the stringer's I ended up having to pull them out from midway back. The old stringers were tabbed on both sides to the floor. But only glued to the hull and tabbed on the inside only. No fiberglass on the outside of the stringer at all. It's no wonder they rotted. But it is 34 years old.
    New stringers are in. Much stronger than before.
    New floor is half glassed in. I ran out of materials.
    Will update as I go.
  2. Likes 89LASER liked this post
    Sep 2010
    nj
    That looks great! I wet sanded a 17 sport fire checkmate a long time ago.... it is a ton of work. What power are you thinking for that? The Spectre is a nice looking boat.
    Apr 2023
    Long island, NY
    I just picked up a 1989 Merc 150. It has a Nosecone and torque fin on the lower unit. It has a Merc racing offshore mid section. And the oil pump block off plate is marked "FULL RACE". I started it and it sounds like a full race motor.
ID:	520212Click image for larger version.
ID:	520213Click image for larger version.
  5. Likes 89LASER liked this post
    Apr 2023
    Long island, NY
    Bought the front bucket seats from Amazon. I had the back seat made to match. I used EVA foam decking instead of carpet. Let me know what you think.
    Not quite done but getting there.
  7. Likes 89LASER liked this post
    Apr 2023
    Long island, NY
    Homemade side panels. Stitching is not perfect but good enough for my first try.
  9. Likes 89LASER liked this post
  10. #6
    Lindenhurst, NY
    Nice work, interior looks great.
  11. Thanks skialot2 thanked for this post
    Likes skialot2 liked this post
  12. #7
    Apr 2023
    Long island, NY
  13. Likes 89LASER liked this post
  14. #8
    Apr 2023
    Long island, NY
    Took it for a ride today. Unfortunately, my brand new hydraulic steering is defective. It does not respond to small movements of the wheel. But I hit 62 on my GPS with a little more to go.
  15. Likes sonicss33, 89LASER, bbezok liked this post
  1. Worked 1989 150 Merc for my 1989 Checkmate resto.
    By skialot2 in forum Boat Build-Ups and Restorations
    Last Post: 10-30-2023, 01:42 PM
  2. 1988 Checkmate Spectra 171
    By kylems4 in forum Hulls up to 20'
    Last Post: 06-14-2019, 08:25 PM
  3. Checkmate spectra 201
    By LAVAR2.5 in forum Props, Setup, and Rigging
    Last Post: 08-19-2010, 11:41 AM
  4. Checkmate 171 Spectra
    By Phillip Mason in forum General Boating Discussion
    Last Post: 08-16-2009, 04:34 PM
  5. set-up for my 21 spectra checkmate
    By themdshrk69 in forum Props, Setup, and Rigging
    Last Post: 02-10-2008, 03:42 PM
