Results 1 to 5 of 5
    I live in Prineville Oregon which is in the central part of the state
    56 PSI regulator question
    I just purchased a Diamond Marine built 260 with some mild porting. It has a 56 psi fuel regulator and was wondering if it should have a 30 psi unit. If so where could I find one.
    thanks, Carter Powell
    Feb 2007
    lily lake WI
    Depends on the ECU with a 56 you can use a a-6 or a63 box curve 56 lbs with a gold 39 lbs you have to use a a5 or A48 personally I prefer the black 56
  3. Likes tunnelmike, pkstv, wcarlyle liked this post
    It is going to have a new Brucato box on it. any ideas or just let them know and take their advice.
    Mar 2004
    Brooklyn Park, MN
    Quote Originally Posted by Carter Powell View Post
    Whatever they give you it will need to be tuned. They send everything out fat to keep people from damaging their motor off their curve. They let you do that on your own!
    RJ
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    I still think my question is what is needed for a motor to need a 56 PSI pressure regulator versus a 39 PSI regulator. Any help on this is greatly appreciated.
    Carter
  1. Regulator/rectifier question
    By delawarerick in forum Technical Discussion
    Last Post: 04-04-2019, 02:19 PM
  2. Regulator Question
    By j_martin in forum Technical Discussion
    Last Post: 10-26-2007, 10:22 AM
  3. Pump & regulator question
    By cocacola in forum Technical Discussion
    Last Post: 07-12-2007, 11:02 AM
  4. Voltage Regulator Question
    By Carter Powell in forum Technical Discussion
    Last Post: 07-05-2006, 02:06 PM
  5. 16 amp Regulator question
    By RB in NM in forum Technical Discussion
    Last Post: 09-15-2004, 08:46 AM
