Results 1 to 11 of 11
    Jun 2013
    Venezuela
    Help Diagnosing Starter Issue
    I have a 225 Mercury Optimax that is having an intermittent starting issue.
    When you try to start it, the system will click repeatedly and never crank the engine. As if there was a faulty connection somewhere. Then sometimes it will start normally with not issues.
    If I hotwire the starter at the engine with a screwdriver, it will always start with no issues so I'm guessing the issue might be somewhere along the cables going to the starter switch.
    Is it possible to test at the harness level so I can confirm the issue is in the cabling going to the switch instead of the engine?
    Here's a video of the issue:
    https://www.dropbox.com/s/bq16yf1tb1...%20AM.mp4?dl=0
    Jan 2020
    Pittsburg, Ca
    Bad starter solenoid
  3. Thanks pcrussell50, CptAJ thanked for this post
    Likes David - WI, pcrussell50, rgsauger liked this post
    Mar 2023
    SW Florida
    what he said. cheap. easy to change.
  5. Thanks CptAJ, pcrussell50 thanked for this post
    Likes rgsauger, pcrussell50 liked this post
    Jun 2013
    Venezuela
    That seems to have been the issue. I replaced it with another one I had from my old EFI and so far the issue hasn't come up.
    Thanks a bunch, guys. It seems obvious in retrospect but I was stuck overthinking it XD
  7. Thanks pcrussell50 thanked for this post
    Jun 2013
    Venezuela
    Welp, looks like we just got lucky for a few days with the new solenoid cause the issue is back (Dont you just hate intermittent problems?)
    Anyone got any ideas as to what else it could be?
    Pekin, IL
    internal corrosion in battery cable..just dealt with it a couple days ago
    Rock
    Team Junk
    Jun 2013
    Venezuela
    Quote Originally Posted by rock View Post
    Rock
    We thought of this but it never fails when we bridge the solenoid directly with a screwdriver.
    Nov 2019
    Canada
    Id run a continuity test on the yellow / red wire. Don't rule out the key switch either. Should be fairly simple to trace it sown now.
    www.InjectorService.com
    Call/Text - 204-326-0390
    Aug 2019
    Palmharbor
    Take the old fashion load tester to it check the amperage compared to the battery directly
    I just had the key switch gremlin. Thought it was the solonoid.
    Mar 2023
    SW Florida
    If the problem is before the solenoid in the low amp circuit the solenoid will not click. If you hear solenoid click, it is either the solenoid or battery cable-connector issue. The batt cable can give enough 12 volts to run everything in the boat but not pass enough amps to fire the starter. But most likely culprit will be the solenoid.
  1. Mercury Tech: Diagnosing bad cylinder
    By Silvershiner in forum Technical Discussion
    Last Post: 10-15-2018, 08:55 AM
  2. Mercury Tech: Diagnosing sick 2.5 260
    By n.jimenez0101 in forum Technical Discussion
    Last Post: 07-26-2018, 11:06 AM
  3. Help diagnosing 1995 2.5
    By wfowahoo in forum Technical Discussion
    Last Post: 12-15-2016, 06:51 AM
  4. Issue with starter not shutting off while crankin motor
    By Swamp boy in forum Technical Discussion
    Last Post: 06-14-2011, 05:48 PM
  5. Help Diagnosing
    By Hydrostream200 in forum Technical Discussion
    Last Post: 07-10-2008, 01:51 PM
