Results 16 to 24 of 24
05-06-2023, 05:34 PM #16
5000 RPM
- Mar 2023
- SW Florida
- 484
- 29
- 79
from the carb number or motor number?
05-06-2023, 06:16 PM #17
Serial number. Carbs are correct for the engine.
Baker343 liked this post
05-06-2023, 06:55 PM #18
5000 RPM
- Mar 2023
- SW Florida
- 484
- 29
- 79
can you tell me the site that gave you the motor from the serial number? thanks.
05-06-2023, 07:43 PM #19
05-07-2023, 07:37 AM #20
5000 RPM
- Mar 2023
- SW Florida
- 484
- 29
- 79
So, looking at my two 2.4 block fronts. They are horizontal Reeds. The three less than 200 hp motors have vertical reeds. Are all 2.4 motors horizontal reeds? or were the few 2.4 150-175 vertical? Or are all 2.0 vertical reeds? this may be a quick easy identifier. pretty sure it is a 90-some-% thing at the least.
05-07-2023, 08:48 AM #21
Early 2.4 200 had vertical reeds. Reed arrangement is a clue but not a positive ID. Fuel pump location is also a clue. 2.0 generally have a starboard side pump location, 2.4 are port side. Neither will be definitive.
05-08-2023, 06:57 PM #22
Junior Member
- Apr 2023
- Arkansas
- 17
I have 2 l6 a 140/115 both like new run perfect,also a1500xs
05-09-2023, 08:29 PM #23
Team Member
- May 2009
- 2,294
- 704
- 135
- 917
- 518
- 7 Post(s)
surprised nobody mentioned it but you can run a magnet tipped flex wire into the cylinders. any hole that is not magnetic is not steel and indicates a 2.4 vice a 2.0. Now... It could still be a 2.4 and be magnetic, but that would mean that all six were repaired by sleeve at some point. I don't imagine that is too common.
-Peter"padded wonder"
__________
the wet:
18’ Bahner bow rider, 2.4/200
the dry:
2003 bmw ///M5
and a handful of clunkers
OnPad liked this post
05-10-2023, 12:28 AM #24
if ya gonna try ta use tha thing and ya know nothin' 'bout it other than "what its supposed ta be" bite tha bullet and pull tha heads.. you'll be way ahead.............. jmo.
OMC Tech: Identify Johnson 225HO Powerhead Without Pulling Head?
By 225ho in forum Technical DiscussionReplies: 4Last Post: 03-06-2023, 07:59 AM -
well my first time pulling the power head!
By whipper in forum Custom Rigging and Metal FabricationReplies: 7Last Post: 03-23-2018, 11:28 AM -
gaskets needed when pulling power head
By stivov1 in forum Technical DiscussionReplies: 14Last Post: 08-23-2016, 07:15 AM -
Mercury Tech: pulling power head
By concord 1 in forum Technical DiscussionReplies: 8Last Post: 08-06-2009, 09:47 AM -
pulling the power head?
By badluck in forum Technical DiscussionReplies: 5Last Post: 05-11-2008, 01:38 AM
