Page 7 of 21 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 LastLast
Results 91 to 105 of 308
  1. #91
    45 Post(s)
    Quote Originally Posted by Tom Smyth View Post
    Let it begin. Doing test strip cuts for the sponson stringers today. funny how every notch is just a bit different in size. Glad to be back working on it ....
    It's funny how you will discover slight variations within hand built one-off race boats when restoring or repair. I ran into the same thing when repairing a starboard sponson on a 1995 hybrid Hoffman champ boat 25 years ago. I personally got the frame tracings from Rick but a few still didn't fit when assembling. Re-lofted and test fit several times before admitting to myself that they would be "different". That's where thickened epoxy and shims come in handy.
  2. Likes Tom Smyth liked this post
  3. #92
    Jun 2001
    quite a bit of work completed. starboard side sponson stringers have been cut, fit and checked for level and straightness to the tunnel bottom side rail. Had to cut the tunnel sides to remove the old transom and figure that will be a weak point if it isn't structurally strong when I piece it back together. Used Clear Fir and all stainless screws. Everything at this point is almost assembled for the TEST FIT ONLY. Once I patch the tunnel9 MM plywood piece in, it will all be disassembled and then glued and screwed into final position. Cutting the Port side stringers tomorrow and will follow the same procedure. With any luck I might have both sponson structures assembled and glued next week. No decking on them for a while is planned.
    Attached Thumbnails Attached Thumbnails IMG_0549.JPG   IMG_0550.jpg   IMG_0546.JPG   IMG_0547.JPG   IMG_0551.jpg
  4. #93
    Dec 2001
    Hey Doc...... my knee hurts...... can ya fix it?.......never mind.... I don;t like Screwss.............Fixin' an old boat........But Who fix'ssss an old boat racer...............Good work Tom......
  5. #94
    Jun 2001
    Rain Rain go away. Makes it hard to wheel this out in the driveway and work on it. A bit of progress. Two of the cross members were about cut totally away, probably for clearance for gas tank or seat. Rebuilding those with 6Mm ply on each side and filler blocks. Front piece is in place for the bottom and top deck stringers to attach to.
    Attached Thumbnails Attached Thumbnails IMG_0597.jpg   IMG_0584.JPG   IMG_0598.jpg
  6. Likes 89LASER liked this post
  7. #95
    45 Post(s)
    Once the hull is "skinned" the cross members have done their job except for frame (sponson) stiffness?
  8. #96
    Jun 2001
    well having those razor thin cross members and the boat totally taken apart I cant just NOT reinforce them at this point....
  9. #97
    Jun 2001
    Well both sponsons have structural members installed and squared up. Last cross member was bonded today. Hope to start fitting the tunnel stringers later this week.
    Attached Thumbnails Attached Thumbnails IMG_0606.jpg   IMG_0607.jpg   IMG_0605.jpg   IMG_0604.jpg
  10. Likes VkingMike, 89LASER liked this post
  11. #98
    Jun 2001
    all tunnel stringers test fit and checked for flatness. a bit of progress..
  12. Likes 89LASER liked this post
  13. #99
    Jun 2001
    and another piece of this boats history. Thank you Bob Holloway....
    Attached Thumbnails Attached Thumbnails 279559781_7686462161394332_1330380310890424142_n.jpg
  14. Likes 89LASER liked this post
  15. #100
    Jun 2001
    and one more.
    Attached Thumbnails Attached Thumbnails 279711782_7686462831394265_6106130950502331709_n.jpg
  16. Likes 89LASER liked this post
  17. #101
    Jun 2001
    HOLY SWISS CHEESE BATMAN !!!!!
    progress today. the first piece of the tunnel bottom was cut and fitted into position. SPent the next few hours drilling holes .....LOTS OF holes....... Splice blocks made, drilled and chamfered. Everything went well with the test fit. More prep to do before it goes in for good.
    Attached Thumbnails Attached Thumbnails IMG_0620.jpg   IMG_0621.jpg   IMG_0619.jpg
  18. Likes 99fxst99, 89LASER liked this post
  19. #102
    Jun 2001
    First piece of the bottom is in. Also the tabs to support the ply between each of the tunnel stringers. Don't have the fancy equipment to do a nice skarf joint. Originally built with a butt joint so that is what i am using. Maybe the second piece in tomorrow. Still wont float yet !!!!!!!!!
  20. Likes 89LASER liked this post
  21. #103
    Jun 2001
    Tunnel bottom in and bonded. Working on the corner pieces. Then about 400 screw holes to fill and sand
  22. Likes 89LASER, JV1, MrBoatYard liked this post
  23. #104
    Jun 2001
    Tunnel bottom in and ready for epoxy. Next step is sponson sides and bottoms.
  24. Likes 89LASER liked this post
  25. #105
    Mar 2016
    cincinnati, ohio
    Is that some kind of wood putty, what did you fill the screw holes with??
  1. 18’ Baker Tunnel Restoration
    By Pilotryan in forum Boat Build-Ups and Restorations
    Last Post: 01-11-2022, 01:08 PM
  2. Allison XST18 Restoration Complete
    By freeebird in forum General Boating Discussion
    Last Post: 07-14-2021, 08:03 PM
  3. Phantom 25 - 30 years ol getting complete restoration
    By Toffen in forum General Boating Discussion
    Last Post: 05-23-2015, 11:56 AM
  4. Engine height on DelCraft Wooden Tunnel Hull:
    By Marchettih2o in forum Props, Setup, and Rigging
    Last Post: 06-25-2010, 12:11 AM
  5. 14' DelCraft Tunnel & 850XS W/SSM:
    Last Post: 10-22-2007, 09:23 AM
