Results 1 to 15 of 16
    May 2009
    7 Post(s)
    2.4/200 trim solenoid are mounting?
    As I rig my 2.4/200 for service replacing an existing 2.0/150, I am asking someone with a dual ram 2.4/200 to take some snaps of how your tilt/trim solenoids are mounted.
    This motor came on an older single ram bracket that I won’t be using here. For ease of rigging, I will mount the 2.4/200 powerhead on the existing dual ram mid. But I can’t find in any of my factory Merc manuals, how to mount the solenoids to the powerhead. I’m pretty sure I can rig something myself, but if there is already a known way that everyone does, I’m eager to copy it.
    The existing 2.0/150 has them on the air box, but the 2.4/200 has a whole different air box than the 150.
    -Peter
    "padded wonder"
    __________
    the wet:
    18’ Bahner bow rider, 2.4/200
    the dry:
    2003 bmw ///M5
    and a handful of clunkers
    May 2009
    7 Post(s)
    Again, it is good clear pictures that would be most helpful here if possible.
    -Peter
    "padded wonder"
    __________
    the wet:
    the dry:
    2003 bmw ///M5
    Aren't those solenoids mounted on the pump, in the boat?
    May 2009
    7 Post(s)
    Only on the single-ram mid. This will be going on a newer style, dual-ram mid. On the dual ram mid, the motor/pump are part of the bracket.
    -Peter
    "padded wonder"
    __________
    the wet:
    the dry:
    2003 bmw ///M5
    Jan 2020
    Pittsburg, Ca
    3 wire or 2 wire trim? Some mount on the coil plate when you have 2 groups of 3 coils on the aluminum plate, or if your motor is older than that then they mount just like you described your 150: on the carb air box plate. If your 2.4 doesn't have the mount screws on the airbox plate then the powerhead was pre 3-ram trim and then there was no place designed to mount them. You may already know everything I just told you, but I just wanted to clarify.
    You may have to make some custom plate to mount them somewhere. I like to mount them in the boat even with the 3-ram trim. I just run the wires into the boat with the jack plate wires and then all my solenoids are together and forget about the powerhead.
  6. Thanks pcrussell50 thanked for this post
    Likes pcrussell50, OnPad liked this post
    May 2009
    7 Post(s)
    You have answered my question... Which is that the solenoids for a 3-ram T'n'T go on the air box. Thanks for that.
    So:
    -1990 powerhead 2.4/200 with WH46 carbs
    -1983 dressing on it (coils, clamshell cowl, air box, engine-side harness, etc...)
    -will be mounted on a 1986 3-ram mid because the boat is already rigged for it
    Since the air box will have been from the single-ram era, it probably doesn't have threaded bosses to mount a plate for the solenoids
    It has six independent coils, screwed to the 80's style exhaust cover (which is mounted to the 1990 block), which AFAICT, is the common arrangement before the water cooled regulators came around.
    I'll either rig up my own mounting plate, or end up doing what you suggested and mount the solenoids inside the boat
    Thanks for the input so far.
    -Peter
    "padded wonder"
    __________
    the wet:
    the dry:
    2003 bmw ///M5
  8. Likes OnPad liked this post
    Houston, TX
    Ummmmmmm…my 90 model V200 has the solenoids at the back I think. Three ram. I can snap a pic tomorrow
  10. Thanks pcrussell50 thanked for this post
    Likes pcrussell50 liked this post
    Mar 2022
    Lake Travis Texas
    Clam shell cowls won't allow rear mounting of solenoids. There is only room for coils.
    Last edited by Jim Speros; 03-31-2023 at 09:59 AM. Reason: Pcrussell knew what I ment.
    Jim
  12. Thanks pcrussell50 thanked for this post
  13. #9
    Pekin, IL
    Drill and tap air box?
    Rock
    Team Junk
  14. Thanks pcrussell50 thanked for this post
  15. #10
    May 2009
    7 Post(s)
    Quote Originally Posted by rgsauger View Post
    I’ve probably confused you with my hybrid situation. The powerhead is a late 1990 (mid-November 1990 build stamp). But the exhaust divider with coil mounting, clamshell cowls, and everything else are all standard mid-80’s. So I would be looking for the standard solenoid mounting scheme for that era, which 25two-stroke kindly shared.
    -Peter
    "padded wonder"
    __________
    the wet:
    the dry:
    2003 bmw ///M5
  16. #11
    Jan 2020
    Pittsburg, Ca
    Yeah, as I believe 1989 was the first year drop-on cowl and last production year 2.4 (maybe 90 was). So in 89 and 90 the motors woulda been 2.4 200s with drop-on and rear (exhaust plate) mounted solenoids. However, hos powerhead is a 1990 but the exhaust divider and cowl are older than 89/90 so that solenoid mounting is out of the question as Jim mentioned: no room back there. So you gotta mount towards the front of the engine.
    Here are some pics of an XR2 from that era that is dying in the back yard.
ID:	517151Click image for larger version.
ID:	517150Click image for larger version.
    May 2009
    7 Post(s)
    Quote Originally Posted by Jim Speros View Post
    Clam shell cowls won't allow rear mounting of coils.
    Thanks, Jim. Normally you are correct. However on this 1990 block, the previous owner put a mid-80’s exhaust cover with the threaded bosses for the coils and the spine where the clamshells hinge. Pretty much standard mid-80’s fare.
    -Peter
    "padded wonder"
    __________
    the wet:
    the dry:
    2003 bmw ///M5
  18. #13
    Jan 2020
    Pittsburg, Ca
    I think he meant to say solenoids not coils. They all have rear mounted coils lol
  19. Thanks pcrussell50, Jim Speros thanked for this post
  20. #14
    TX......somewhere?
    for tha 200 2.4's pre '89 there is a solenoid bracket in this dia.. its in dia with tha three ram trim at tha top.. it mounted on top front of motor......................... last one we had ta fab ourselves.. couldn't find one!
    POWER TRIM COMPONENTS - 1987 Outboard 200 [ELPTO] 1200727 | Crowley Marine
    tha one stroke shows was on tha 2.0 and 175's only.. anything that had vertical front.
  21. Thanks pcrussell50 thanked for this post
  22. #15
    May 2009
    7 Post(s)
    Having trouble visualizing what you mean by "top front of the motor". Like where this plate is?
Name:	trim solenoid plate???.jpg
    -Peter
    "padded wonder"
    __________
    the wet:
    the dry:
    2003 bmw ///M5
  1. 2000 Optimax Starter Solenoid mounting?
    By offthefront in forum Technical Discussion
    Last Post: 09-11-2020, 07:52 PM
  2. trim solenoid
    By tcrabtree in forum Technical Discussion
    Last Post: 10-07-2009, 04:27 PM
  3. Trim Solenoid
    By bill mason in forum General Boating Discussion
    Last Post: 10-10-2001, 08:42 PM
  4. trim solenoid
    By bill mason in forum Technical Discussion
    Last Post: 10-10-2001, 02:47 PM
