Results 1 to 14 of 14
03-25-2023, 08:24 PM #1
Team Member
- Lake Coochiching, Ontario
- 8,438
- 43
- 399
- 663
- 2113
- 6 Post(s)
do you use spacers to index your Optimax plugs?
I have been just buying a lot of plugs and using the ones that index correctly in each hole. It's time consuming.
Gapping and Indexing - NGK Spark Plugs
Spark Plug Indexing Washers - Free Shipping on Orders Over $99 at Summit Racing
How common is it to use indexing washers?
03-25-2023, 09:36 PM #2
I never index optimax plugs and noone at Mercury has ever told me to except on DSI motors which I never see.
Never had a fouling issue unless something else was wrong with the engine.
Etecs I index and I just buy hella plugs.
Note added:
I don't work/build high hp optimax motors. Nothing over 250 hp. On a 300xs or any modified xs making big HP then it might be worth it, but on the typical off-the-shelf optimax I'd say its pointless.Last edited by 25two.stroke; 03-25-2023 at 11:07 PM. Reason: added note
03-26-2023, 07:33 PM #3
Team Member
- 8,438
- 43
- 399
- 663
- 2113
- 6 Post(s)
It's interesting as we have both the 200XS ROS and a 150 HO Etec that need to have the plugs indexed. The Opti plugs get a lot more oil covered, despite far less idling and a lot more high rpm use.
The Etec plugs are much easier to get at. Evinrude says to change every 3 years - although they still look good.
A related question about the plugs - is it possible to clean the oil off a used plug? It's not as if the electrodes seem to wear.
03-26-2023, 07:53 PM #4
I'm likely to get some push back but, I think indexing plugs is a sign of a design short coming.
Jim
03-27-2023, 09:13 AM #5
Team Member
- 8,438
- 43
- 399
- 663
- 2113
- 6 Post(s)
Indexing might be a design shortcoming, but it's recommended for both the Etec and Optimax direct injected engines, so I am stuck with it. It's also required on some (all?) Mercedes Benz direct injected engines, but I can avoid buying one of those.
NICE PAIR liked this post
03-27-2023, 11:41 AM #6
5000 RPM
- Dec 2019
- Spring Lake MI
- 597
- 52
- 212
- 534
I find that the washer thickness needed to get them where you want is less then ideal.
TJ @ Baker Engineering
Tuff 24 300xs
Tuff 16 90 Yammie
3.75@199mph with LSX power!!!
David thanked for this post
03-27-2023, 12:19 PM #7
Team Member
- 8,438
- 43
- 399
- 663
- 2113
- 6 Post(s)
Good, someone uses the washers. I hope less the ideal means trying fewer plugs per hole
03-27-2023, 11:23 PM #8
I gotz some of them Opti-pop heads in the recycle pile out back. Never looked at them really close, but I believe the plug is tucked up in a small pocket at an angle. Then they put a cup (like a diesel) in the piston to slow the air down. I rekkon they have better luck lighin the lean charge easier with the gap facin down towards the cup.
For the rest of us, The gap faces towards the exhaust (valve) port. It might not make any more power on certain applications, but it will allow all the plugs to look (from the perspective of , squish, swirl, fuel wash, etc.) the same while your "arriving" @ a tune-up ..
03-27-2023, 11:36 PM #9
Well howdy, Chaz. You’re back!
03-28-2023, 05:54 AM #10
03-28-2023, 08:01 AM #11
Team Member
- 8,438
- 43
- 399
- 663
- 2113
- 6 Post(s)
03-28-2023, 09:40 AM #12
03-29-2023, 12:05 AM #13
03-29-2023, 09:22 AM #14
RG , Thank you for the kind words ...
Optimax spark plugs
By Low_Psi in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 14Last Post: 10-09-2014, 03:11 AM -
2002 OPTIMAX 200hp fouled plugs
By Wayne Koeppe in forum Technical DiscussionReplies: 1Last Post: 07-22-2007, 11:13 PM -
Spark plugs for merc. optimax 225
By Sutphen20 in forum Technical DiscussionReplies: 3Last Post: 06-29-2005, 02:28 PM
