Results 1 to 15 of 29
    Mar 2023
    Ann Arbor MI
    89 champion swapping to a Bridgeport ? Any suggestions ?
ID:	517028Well here we go,
    me and my brother been looking to re power my late fathers old champion bass boat, currently the boat has a 200 blackmax, we found a deal on a Bridgeport 2.4 EFI, guy had it rebuilt in the 90’s and it’s been sitting in a heated barn since. I bore scoped it and all looks good, motor was rebuilt in Ft.lauderdale by 4-play marine, then shipped upto Michigan.
    initially we planned to to swap the powerhead, however the guy has additional motors for sale only one standard rotation and two counter rotation, we plan to pick one of those up with around 80 hours on it in addition to the fresh rebuilt powerhead, MY question is once I go over the other engines would buying a counter clock turning lower end be a big deal, I’ve searched in here and it seems indifferent. But curious.
    secondly we will need to build a fuel system, the complete motor will come with a Bosch fuel pump, we thought about putting a dumped cell in I’ve read where the CG doesn’t like that but curious what others do since most EFI pumps don’t like to pull, and I don’t want to lose prime.
    we live in Michigan and fish inland lakes, in a summer we might put 30 hours on the motor, and don’t plan to run the piss out of it,
    we don’t mind working on it, gives us something to mess with, but looking for some honest advice on the Bridgeport motors. And advice to us on doing the swap? We better off just rebuilding the 200 on it?
    thanks
    For fishing? For sure.
  3. Likes rgsauger liked this post
    Houston, TX
    Welcome to scream and fly!! Is your 200 tired or blown up? Have you checked on bassboatcentral for specific champion setup tips?
    either way, it’ll be fun!
    TX......somewhere?
    looks like its been tweaked on?.. has 56lb fuel stuff.. # of tha ecu?.. (digital or analog) do you know anything else 'bout tha motor? what year is tha 200?.. champs are pretty good, solid hulls but are pretty heavy ta start then add all tha fishin' junk jus makes it worse.. BP's don't like weight.... ya may not see a difference worth puttin' up with tha finckyness (sp?) SOME BP"s can be........... one other thing that MIGHT come up is tha BP is normally run ona one piece, (no poppet) offshore type adapter so ya might need ta do some tweakin' on tha coolin' junk................ jmo
  6. Likes rock liked this post
    Apr 2017
    pa
    5 Post(s)
    Champion boats are heavy. Not the place for a Bridgeport. A 2.5 200 would be better suited for you
  8. Likes Spolly07 liked this post
    Apr 2017
    pa
    5 Post(s)
    As far as counter rotating motors, as far as I know, all powerheads turn the same direction. The difference is the lower unit.
  10. Likes Spolly07 liked this post
  11. #7
    Sep 2006
    Key Largo, Fl
    Quote Originally Posted by bullet123 View Post
    Lots of racing powerheads are set up to run counter clockwise...different flywheel,starter,and the trigger is usually fixed,Chris
  12. Likes Spolly07 liked this post
  13. #8
    Mar 2022
    Lake Travis Texas
    A wide variety of opinions shared.
    I for one would go the bridge port route if it came complete. The left hand lower unit will work fine but can limit your prop selection. The fuel system will need a puke tank and low pressure pump in the boat.
    With that said understand service parts may be difficult to locate. Many parts are NLA for older engines. And as always you are spinning the wheel on a rebuilt.
    Jim
  14. Likes Spolly07 liked this post
  15. #9
    Pekin, IL
    I have owned several Champions and while great boats they are not light. Rebuild the 200 and sell the BP to pay for 200 rebuild. JMO
    Rock
    Team Junk
  16. Likes David - WI, Spolly07 liked this post
  17. #10
    Jul 2008
    severn bridge
    I only reversed omc's can't remember a merc maybe sst140 motor?
    your going to need more than a powerhead to put that BP on a max mid! I'd go for a complete with an offshore mid if he has one!
  18. #11
    TX......somewhere?
    tha one in tha pic is a C rotator powerhead.. don't know if he's meanin' C or CC "powerhead" or gear case?.. most hot rod CC rotatin' power heads run on speedy's anyway................... we've run BP's on champs (in tha early 90's) before and just weren't worth tha effort when in "fishin' trim"................. jmo.
  19. Likes Spolly07 liked this post
  20. #12
    Mar 2023
    Ann Arbor MI
    Quote Originally Posted by rgsauger View Post
    Current motor is tired, gets a little warm over 5G, and down about 6mph from 6 years ago. and rather rebuild before it lets loose. The BP’s we’re to be for fun, sound good and a few rips across the lake.
  21. #13
    Mar 2023
    Ann Arbor MI
ID:	517068Click image for larger version.
ID:	517069Click image for larger version.
ID:	517067Click image for larger version.
    when you 56# you mean injector wise?
    our current 200 is a 89.
    I will get the ignition details shortly brother is picking up the powerhead currently.
    here is some pics, along with rebuild receipt, bottom motor Attachment 517063
  22. #14
    Mar 2023
    Ann Arbor MI
    from what I’ve read that seems to be the case, I guess I was wondering is their any concern for parts on counter rotating lowers ?
  23. #15
    Mar 2023
    Ann Arbor MI
    Quote Originally Posted by Jim Speros View Post
    I believe we are planning to buy the complete along with the rebuilt powerhead as a spare,
    fuel system is gonna be completely redone, thinking fuel cell with bottom sump.
  1. Swapping 260 > 280 powerhead
    By tripower in forum Technical Discussion
    Last Post: 07-30-2019, 06:37 AM
  2. Bridgeport help and suggestions
    By D-Bay Runner in forum Technical Discussion
    Last Post: 04-07-2013, 07:00 AM
  3. Swapping Cowls - HELP!
    By Fassster in forum Technical Discussion
    Last Post: 05-12-2010, 09:05 AM
  4. ECU Swapping
    By gselite in forum Technical Discussion
    Last Post: 01-07-2005, 11:37 PM
