Results 1 to 2 of 2
    Mar 2023
    Miami Florida
    Cool 2022 21 Paramount
    1992 21 Paramount
    This is the cleanest 21 paramount available. It sits on a 2022 dual axle aluminum trailer this boat was assembled with only the best parts. It was completed in 2022 and is equipped with a 2018 225 Verado tuned to 340hp. It has a USP marine tuning ultimate performance kit system with scoop and a Sport master Gearcase 1.85 gear ratio built by (offshore out drives). The engine currently has 65hrs its mounted to a brand new bobs jack plate controlled by a Teleflex paddle shift switch, with a custom built transom bracket by ROC Marine group. The bracket was custom painted to match the boat not powder coated. The boat was custom rigged with all highest quality, stainless steel hardware with brand new mercury electric power steering. Along with all new DTS rigging and throttles boat has two batteries one engine group 34 and one house group 31 both AGM. Maintained with a 1240 Pronautic battery charger along with a 150 amp isolator and DVSR for engine charging. The sound system is impressive, it has 6 7.7 4 8.8 and 2 10 in subs all JL m6 and JL amps with a fusion head unit and remote all stereo equipment still under factory warranty.
    In addition, it has 2 Lumitec seablaze x2 spectrum underwater lights. all the undergunnel lights are RGBW, Along with the two clear custom engraved rear hatches which are also illuminated. The boat also has Lenco high performance 12x14 electric trim tabs with integrated indicator system. The dash was custom built to acomadate a Garmin 8612 in the center, while still having more room for navigation and information with an additional Garmin 743xsv. This also displays perfect view of the bottom, with an airmar b60 thru hull transducer installed well away from the pad and running surface to avoid affecting the performance of the boat. All new stainless rub rail along with custom tri-layer seadeck to finish the build. Pictures do not do this boat justice this is a must see boat. This is a complete package, this includes all bumpers, ropes, cooler, bbq, Taylor made sunshade and everything you need to make this a memorable summer.
    I HAVE RECIEPTS FOR EVERYTHING!!!!!!
    Please feel free to contact me or my brother with any questions
    (786)651-6578
    (954)446-5068
    $64,999 OBO
    Attached Thumbnails Attached Thumbnails 2435421B-3DBB-4A00-BBF9-1A6BD5B15672.jpg   427EC3B2-71B5-4954-9F48-70670AF9259D.jpg   28D18309-F11C-47C3-8907-70A50291D220.jpg   55018094-401F-44E2-AB97-A565FED4A69B.jpg   60786FD7-4392-490B-AEB6-405945D16ADF.jpg
  2. Likes Marcos, JBS liked this post
    May 2001
    great south bay
    What year is on the Hull ID?
  1. Toys Run Palatka 2022
    By sonicss33 in forum Upcoming Events, Races, and Gatherings
    Last Post: 12-03-2022, 12:09 AM
  2. 2022 f1
    By CDave in forum Other Motorsports
    Last Post: 04-03-2022, 10:04 PM
  3. 2022 Events
    By JDChase in forum General Boating Discussion
    Last Post: 09-06-2021, 09:14 PM
