Results 1 to 9 of 9
    Mar 2023
    2001 200 efi bogging out of the hole
    New to the forum and need some direction. My 200 efi bogs coming out of the hole….just sits there at 2000 rpm for as long as you want to stay on the throttle. If you just tap the trim switch up or down she lurches out of the hole and runs like a scalded dog……..checked battery voltage while running. 14.5. When you tap the switch it goes down to high 13’s and back to 14.5 and continues running well until I come off plane and attempt another hole shot. I pulled the fuses for both voltage regulators and it takes the trim switch out of the equation. It still bogs and stumbles for 30 seconds before getting up and going. But tapping the trim switch up or down has no affect on the motor with the regulator fuses out.
    Usually a bog is too much fuel or not enough. Sounds like you are over fueled IMO. Never heard of the trim doing anything like you describe. Do you have the black boxes removed?
    Pekin, IL
    Welcome to the site. What boat and motor and prop pitch. Has it been working but just developed this issue?
    Rock
    Team Junk
    Massapequa NY
    Wiggle the wheel
    Mar 2023
    Which black boxes?
    Mar 2023
    Procraft 200 super pro, merc 200 efi, 25p fury. It turns the prop no problem when running right.
    TX......somewhere?
    ya got something happenin' thats not supposed ta be (electric, wiring)..... trim ('lectrics) stuff SHOULD BE completely separate from anything else electrically... other than they all get batt. feed (positive) from same spot.. could be a ground issue with either and/or both circuits, trim and/or chargin'???
  8. Likes David - WI liked this post
  9. #8
    Mar 2023
    I cleaned every ground on the motor and the battery. No change.
  10. #9
    Nov 2021
    Northwest
    If your sure your fuel system is legit?
    Things to check are.
    Spark, when the problem occurs.
    Trigger throw.
    Stator test with a dva.
    Trigger test with a dva.
    Bias test.
    Correct spark plugs?
    This is just a partial list.
  1. 2001 135 Optimax with an empty hole.
    By papalobster in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 08-09-2018, 08:35 AM
  2. Replies: 31
    Last Post: 08-03-2016, 05:52 AM
  3. 2001 optimax 200 bogging and missing
    By wtlee3 in forum Technical Discussion
    Last Post: 12-19-2011, 11:03 PM
  4. Mercury Tech: 150 xr2 bogging hole shot
    By shawn2597 in forum Technical Discussion
    Last Post: 04-01-2011, 05:36 PM
  5. Mercury Tech: 2001 Merc 250 EFI stumbles/misses out of the hole...
    By phaster in forum Technical Discussion
    Last Post: 06-24-2010, 12:36 PM
