Results 16 to 30 of 42
    May 2013
    Huntiington Beach Ca
    That aluminum prop will not provide much lift or carry your hull. Don't give up on your OMC. Look for a shooter prop, they can be found fairly cheap
  2. Thanks Spaceman Spiff thanked for this post
    Likes David - WI liked this post
  3. #17
    Sep 2022
    Portland, OR
    Quote Originally Posted by Baker343 View Post
    I'm only finding as low as 23 pitch. Is that too much?
  4. #18
    May 2013
    If you're running a 21 aluminum right now at 5000, I would keep looking for a 19-21 shooter. Or buy and test and resell the 23
  5. Thanks Spaceman Spiff thanked for this post
  6. #19
    Sep 2022
    Portland, OR
    What rpm should I ultimately be looking for?
  7. #20
    Sep 2022
    Portland, OR
    Actually, i raised it up and broke it free and vented up to 5800
    without an increase in boat speed.
    I found a 12.75 x 23 SS prop for $50. I'll give that one a try at the same height and see if it holds better.
  8. #21
    13.5 22P raker
  9. Thanks Spaceman Spiff thanked for this post
    Likes David liked this post
  10. #22
    Sep 2022
    Portland, OR
    Can someone please recommend a prop that doesn't cost twice as much as the boat/trailer did? lol
    I know I know. Speed costs money. How fast do you want to go?
  11. #23
    Lake Coochiching, Ontario
    I have bought two rakers, 20 and 22” pitch for our ski boat. Both were under $200. One was here and the other was EBay. For my money Rakers are hugely under appreciated.
    You could also look for a Renegade. A 21 Renegade came with my 16’ Baja.
    I also really liked a 17” 4 blade Stiletto prop. It was clearly more than 17” pitch and it lifted well. That prop was not run on the Baja, different boat.
  12. #24
    Sep 2022
    Portland, OR
    Quote Originally Posted by David View Post
    How about a Stiletto 3 blade 13.25 x 21"? I see one of those on CL for under $200.
  13. #25
    If I were spending my money I would try the 3 blade Stiletto. You can always sell a prop that doesn’t work out. It is sort of like renting a prop.
    Of course that logic leads to the 11 props in my crawl space
  14. Likes David - WI, Baker343, FMP liked this post
  15. #26
    May 2013
    Quote Originally Posted by Spaceman Spiff View Post
    Not many people can give you the magical prop. You have to buy and test like the rest of us. I'm not an OMC guy, but like we've been recommending a bow lifting 19-21 is a good start. Remember you have a Tahiti ski hull. Most of us have ski props and faster props
  16. Thanks Spaceman Spiff thanked for this post
  17. #27
    13.5 22P raker
    How healthy is that Johnny, maybe try a 21-20P if you see that first.
  18. #28
    Sep 2022
    Portland, OR
    It seems fine. It just doesn't have PTT. I have a parts engine with PTT, but I'm still trying to figure out how to swap the transom bracket. It's not the kind that can be removed without messing with the motor. I'm sure PTT would make a big difference. It's tempting to put my 1983 Mariner I6 115hp with PTT on there. Seems like the props available for that motor are cheaper and more plentiful.
  19. #29
    Set it and forget it, the right prop height and trim.
  20. #30
    Can't you put the good power head on the motor that has power trim?
  1. Tahiti?
    By boatnut62 in forum General Boating Discussion
    Last Post: 03-19-2022, 09:44 AM
  2. My Tahiti
    By Tahiti Steve in forum General Boating Discussion
    Last Post: 08-04-2012, 09:59 AM
  3. 21' Tahiti
    By slowmover in forum General Boating Discussion
    Last Post: 08-09-2009, 06:26 AM
  4. The Big Ass Tahiti
    By WICKEDRISTER in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 09-21-2007, 07:50 PM
