Results 1 to 15 of 18
Thread: Kill Switch Lanyards - USCG Reg
10-20-2022, 02:51 AM #1
6000 RPM
- Nov 2006
- 1,756
- 18
- 182
- 86
- 783
- 45 Post(s)
This was the first year for mandatory kill switch lanyards (USCG). Anybody see someone getting written up for not having one?
02-12-2023, 06:44 AM #2
I had not seen this question until now.
I generally wear the lanyard, it is required at most of the events I attend.
But for me I do not rally consider it important since I run with a foot throttle so the boat comes to idle if I ever get out of position.Regards,
Charlie North
If it ain't broke, modify it.
87 Glastron CVX20 Hull
02-12-2023, 02:31 PM #3
I thought we figured out lanyards aren't required... but if the boat has one, you have to wear it (boats under 26').
https://uscgboating.org/recreational...ff-devices.php
02-21-2023, 12:57 PM #4
6000 RPM
- Nov 2006
- 1,756
- 18
- 182
- 86
- 783
- 45 Post(s)
David - WI liked this post
08-07-2023, 03:02 AM #5
New Member
- Aug 2023
- Pasadena, California
Kill switch lanyards are required in 49 states and the District of Columbia. The only state where they are not required is Maine. However, even in Maine, a kill switch lanyard is still required if the boat has an outboard motor with more than 135 horsepower.
08-07-2023, 05:57 AM #6
6000 RPM
- Aug 2015
- Southeast
- 1,287
- 139
- 124
- 58
- 792
powerabout liked this post
08-08-2023, 02:44 AM #7
New Member
- Aug 2023
All safety rules are written in blood
08-17-2023, 11:08 AM #8
08-24-2023, 12:26 PM #9
6000 RPM
- Nov 2006
- 1,756
- 18
- 182
- 86
- 783
- 45 Post(s)
08-24-2023, 12:33 PM #10
Still not clear to me that everybody needs one.
Q6. What boats need to have an Engine Cut-Off Switch installed?
A6. Boats less than 26 feet in length that generate more than 115lbs of static thrust (~ 2-3hp) and were built beginning in January 2020. If the boats’ primary helm is inside an enclosed cabin it is not required to have an Engine Cut-Off Switch.
08-25-2023, 06:23 AM #11
I had not previously seen the 2020 date.
I wear mine though.
Way back in the early 70s I was ejected out of my 3 points hydro, An 8' hull with a 20H Merc on it.
It ran 60 according to radar,
One of the pulley blocks unbonded from the hull.
When the pulley broke free the boat spun aggressively ejecting me.
I was underwater, still kneeling, I think my hands were still one on the wheel and the other on the CW throttle, or so I thought.
When I surfaced my helmet was over my eyes, water dumping out. My boat was just sitting there as peaceful as could be, engine cocked over hard to the left.
As I walk away from writing this I recall now why my ankle is in such bad shape today. The foot was caught under the side hull when I was ejected as they were splayed out in a kneeler. Something about that moment 53 years ago.Last edited by CharlieN; 08-25-2023 at 06:36 AM.
Regards,
Charlie North
08-25-2023, 10:17 AM #12
I'm not arguing that people shouldn't use them... only questioning what the new "law" actually says.
08-25-2023, 10:51 AM #13
What year was your boat built? After 2020 it must have the switch.
Regards,
Charlie North
08-25-2023, 11:21 AM #14
But you don't have to wear it fishing, docking, idling, trolling, or passing through a slow-no-wake zone (which is where most of the people I see get pulled over for life vest/registration checks).
08-25-2023, 12:12 PM #15
That regulation only refers to boats being equipped with the system. The regulation clearly states the year of manufacture the builder had to start compliance.
The regulations for wearing the lanyard are set by each state.
Personally I do not care about regulations for PFDs or lanyards because I wear them by choice.
I am pretty much sure that wearing safety gear, Everyone on this site is pretty darn well set with their own safety protocol.
When I paddle my high performance carbon canoe I wear my vest all the time, that boat will spit you out whenever it chooses.
In my powerboats, I feel no need to wear the vest idling in a channel. But when my foot is on the throttle or the water is getting angry I have my gear on.Regards,
Charlie North
kill switch
By jerry in forum General Boating DiscussionReplies: 5Last Post: 07-16-2011, 07:10 AM -
Mercury Tech: 2.4 kill switch
By Quinten in forum Technical DiscussionReplies: 9Last Post: 06-29-2008, 05:39 PM -
Kill switch
By Bill H in forum Technical DiscussionReplies: 1Last Post: 05-30-2004, 11:13 PM -
How to kill your fuel pump with a Merc kill switch
By MODVP22 in forum Technical DiscussionReplies: 23Last Post: 05-08-2004, 08:26 PM
