Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
    shreveport,la
    Quote Originally Posted by SJD1974 View Post
    Has anyone here done any work on standard replacement Wiseco pistons for a 2l black Max?
    I would like to lighten them up. I am doing all the manual work to this that I can, have very limited funds I'm no stranger to grinding in precision.
    I don't care how small the mod is!
    Thanks.
    I wouldn’t bother with lightening pistons. You’ll see no performance gain and it will only weaken the part. You can balance them but I wouldn’t take any real weight out, especially out of the skirt
    Erik Kiser
  2. #17
    Quote Originally Posted by patchesII View Post
    If you equal weight them, drill the wrist pin end in both sides to get the reduction, leave the piston. Won't take as much material either compared to the aluminum.
    Jmo
  3. Likes OnPad liked this post
  4. #18
    Nov 2021
    Holland,Michigan
    I don't know about it being copy of a old Procraft hull but this boat gets up on the water fast and is just skipping through the water . It's in the water 3.25in with a manual jack plate set back 6in with a 21 laser 2. I know I've heard it's a terrible prop.
    Had video of it running up on the little bit of pad that was in the water.
    Can't afford a different boat.
    1988 Bass Tracker 1800FS Tournament W/ Mercury 175 XRI 2.5
  5. #19
    Nov 2021
    Holland,Michigan
    I appreciate all the information, please keep it coming.
  6. #20
    Nov 2021
    Holland,Michigan
    As far as speed goes we currently run at 51 with the boat loaded, both boys and all thier fishing gear full 26gal of fuel and me.
    Would like to get 56 out of it. That would help us alot when running 25 miles in one direction. Time of bait in the water is very important. Speed equals more time in the water. We are but a small high school team doing the best with what we have.
    Trying to compete with $50000 bass boats.
  7. #21
    Nov 2021
    Holland,Michigan
    My boys finished 5th in our state of Michigan and I am very proud of them. I'm trying do my part by getting them time in the water. That's out of somewhere around 2000 teams.
    That's my end goal here!!!!
  8. Likes rgsauger liked this post
  9. #22
    Nov 2021
    Holland,Michigan
    Thank you for being apart of that by helping me.
  10. #23
    Aug 2020
    Dickson, Tennessee
    Well i just found a crack in the exhaust chest area so i dont know how much i will be doing!Attachment 515072
    Thanks for the info.
    Looks like a minor crack in the surface to me. If you weren't getting water in you can probably peen it and never worry about it again. For the chest, like most v6 mercs, blending that exhaust exit downward towards the bottom does help the flow a lot. 2.0L dumps at the bottom are big enough already so directing the flow towards that exit is what it wants to do. From my experience with 2.5Ls, combining that with blending the rod slots into the transfers at the bottom of the cylinder is a game changer and no port timing mods are necessary. These two things combined will also cause it to move a crap ton of fuel through so tuning it is a must. Cant do these things and still run the same jetting in carbs and/or ecu curve without issues IMO. Just my thoughts on it.
  11. Thanks SJD1974 thanked for this post
    Likes Baker343 liked this post
  12. #24
    Nov 2021
    Holland,Michigan
    Quote Originally Posted by Smalltownbassin View Post
    Was planning on going up 2 maybe more jet sizes. I have 80s in now.
  13. Likes Smalltownbassin liked this post
  14. #25
    Nov 2021
    Holland,Michigan
    Anybody on here ever drill small holes in piston for additional lubrication of the cylinder walls?
  15. #26
    Just in a Bridgeport to keep bridge cool and not crack.
  16. #27
    Nov 2021
    Holland,Michigan
    A little off subject but can anyone tell me why this rod has a copper or bronze coating not sure witch and can any be removed to clean up rough edges?
  17. #28
    Nov 2021
    Holland,Michigan
    Quote Originally Posted by RBT View Post
    Crack is fine, they all do that.
    Best advice would be to find a 2.5, the 2.0 is a fine motor, but the 2.5 is a country mile farther ahead. MUCH more torque. 200FF or EE block in stock form will out perform any lakeable 2.0
    RT
    I have that 2.5 now. It's a 1994 175 2.5!
  18. #29
    Jul 2013
    It’s a copper plating that’s done to the rod so when it’s case hardened the carbon only goes in the bearing areas. The bearing areas need to be 60 Rockwell C for the bearing needles to ride on. If the rest of the rod was that hard it would break.
    As far as removing it to balance or stress relief, it’s not a problem.
  19. Likes LakeFever liked this post
  1. Mercury 2.0 exhaust chest porting
    By 2.4Viper in forum Technical Discussion
    Last Post: 02-07-2021, 04:22 PM
  2. What should I do with this EE block? Porting and exh chest...
    By Kennay in forum Technical Discussion
    Last Post: 02-10-2020, 10:30 PM
  3. My 2.5 Merc Exhaust Chest Re-Work Attempt
    By QuarterHorse in forum Technical Discussion
    Last Post: 02-08-2018, 08:36 PM
  4. Exhaust putty for exhaust chest work?
    By Mr. Demeanor in forum Technical Discussion
    Last Post: 09-02-2013, 11:29 PM
  5. exhaust chest
    By jody in forum Technical Discussion
    Last Post: 03-28-2002, 10:26 AM
