Page 9 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 121 to 135 of 158
Thread: My MGB
  1. #121
    Jul 2013
    Have you seen this MGB shop. Doing restorations and restomods. Read an article about them found it interesting.
    https://snakeriverclassics.com/
  2. Thanks Instigator thanked for this post
    Likes Instigator liked this post
  3. #122
    12 Post(s)
    Not that far in yet.
    I am seeing that to do these motors stock is cheap, to hot rod one?
    Not so much!
    Quote Originally Posted by Forkin' Crazy View Post
    What oil do you guys run? All or most of the early 911 guys run Brad Penn because of the zinc content. I just flushed mine twice and the oil is now clear. Time to order oil. And to fill mine it is about 100 bucks not including the filter, drain washers, and gaskets for the sump.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  4. #123
    12 Post(s)
    Actually, I have.
    And I like them a lot.
    Pays homage to the MG marque while applying current tech to it.
    I really like their motor of choice too.
    As I go down this path I continue to remind myself, this ain’t about going fast.
    I sold that car.
    This car stock, at 90 hp was an absolute hoot!
    W/rebuilt suspension and 150 hp, I hope to be content w/it.
    Quote Originally Posted by Onetime View Post
  5. Likes doug7488, Frank Molé, Forkin' Crazy liked this post
  6. #124
    Nov 2001
    Lake Charles, Louisiana
    Best oil I ever ran across was Schaeffer Oil. When I was working my first job as a diesel mech. when it came time to overhaul any of the diesel's running this oil the rod and main bearings looked brand new. The cylinder liners still had great cross hatch on them.
    When they switched oil to one of the big brands, I forget which one, when it came time to overhaul a diesel engine everything looked like it needed changing.
    When I install the 383 I'm building for my truck I'm gonna switch from Shell Rotella T6 to Schaeffer SynShield OTR Plus.
    Schaeffer Oil---> https://www.amazon.com/Schaeffer-Man...st_sto_dp&th=1
    93 STV Mod VP/MERC 2.5 200
    Proverbs 4:18-20
    -- John F. Kennedy 1962
  7. Likes Instigator liked this post
  8. #125
    Central Florida
    150 hp
    I may have missed it. Are you supercharging?
  9. Likes Instigator liked this post
  10. #126
    Nov 2001
    Quote Originally Posted by BarryStrawn View Post
    I shouldn't say anything but he has a bunch of performance decals. Each one is worth at least 5hp so...
    Proverbs 4:18-20
  11. Likes Instigator liked this post
  12. #127
    12 Post(s)
    Nope.
    N.A.
    I like old school and as little complication as possible.
  13. #128
    Central Florida
    150HP from a BMC B takes a lot of imagination.
  14. Likes Instigator liked this post
  15. #129
    NE Louisiana
    Quote Originally Posted by CDave View Post
    I used to run that in my diesels, but after putting 300K on my dually on regular oil, I figured it wasn't worth it unless you stretched the changes out to at least 10-15K.
    Brad Penn, or now called Penn has zinc and phosphorous in it. More or less made for older engines without emissions.
    https://penngrade1.com/
    Nice article.
    https://rislone.com/blog/engine-oil/...older-engines/
  16. Thanks doug7488 thanked for this post
    Likes CDave liked this post
  17. #130
    12 Post(s)
    Yes, sir.
    As you know, I’m OK with swimming up stream.
    Getting accurate info has been an issue though.
    Lots of old school guys that only do it one way, same as has been done since they were new, 50 yrs ago.
    Then there’s the SCCA crowd that it is limited to what they can do by class rules, which I have none of.
    Then you have the Brits that list Hp at the rear wheels, which they call the rolling road and have wildly variable #s.
    I really wanted to team up w/a shop, and still may, for parts and machine work in exchange for info.
    From what I can tell, the best stock B (18V) motor made 102 hp at the crank.
    So if I can add 50% to that w/my mods, which is fairly standard fare to most stock motors, I’m done.
    Bottom line is, I’m having a blast and frankly could care less where I end up.
  18. Likes BarryStrawn, CDave liked this post
  19. #131
    12 Post(s)
    Forgot how much fun drum brakes were!
    Rear suspension bushing upgrade/replacement is done, as is conversion to modern, adjustable shocks and of course brakes.
    I should now have brakes on all 4 corners compared to the one when I bought it!
    Was 65 here in Ohio today and I came close to dropping it on the ground to go for a ride.
    Attached Thumbnails Attached Thumbnails 0B738E45-2A74-4AF6-9678-D044F24D943E.jpg
  20. Likes doug7488, CDave, Forkin' Crazy liked this post
  21. #132
    Dec 2001
    My dad had a bug eye,,,,, I sat in the rear SEAT....?......Went up to the state park,,,,,, what a ride......150 HP.....?.....I have a Fiat 124 spyder that I am going to get going Sooooome day..,,,,,Was thinking of puttting on 2 Merc carbs from a 2.5..... the pumpers..... Kinda like webers............
  22. Likes Instigator liked this post
  23. #133
    NE Louisiana
    Ah, brakes... More important than the go button. All of my calipers have been restored by professionals, new rubber lines, pads, and hardware. Needless to say it put a quite a dent in my pocketbook! I DID reseal the master myself though, And my parking brake is a DRUM assembly INSIDE the rear calipers. And very effective!
    Looks awesome!!! Simple things can be so fun!
  24. Likes Instigator liked this post
  25. #134
    Dec 2001
  26. Likes Instigator liked this post
  27. #135
    Jun 2004
    long island
    That is a deal for the able bodied
    Austin’s are good looking cars
    there was a local one around with a small block ford in it
    very cool
  28. Likes Instigator liked this post
