Results 106 to 120 of 158
Thread: My MGB
10-01-2022, 06:17 AM #106
Couldn’t get this sticker in focus but was hilarious.
Was on a Triumph Spitfire on the ferry back to mainland.
Says, “the parts falling off this car are of the finest British quality” !I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
12-28-2022, 08:35 AM #107
Some progress:
Found, painted and installed a front air dam
On version VI of my ram air
Best news came from a couple of calls yesterday.
Found a donor motor and an MG shop to supply my parts and do the machine work on block, head etc.
Will p/up motor in next wk or two and order aluminum head next.
Ordering bare head which I will port then have shop cut for bigger valves etc.
Currently replacing all the rotted, rubber suspension bushings w/polyurethane.I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
12-28-2022, 09:05 AM #108
Screaming And Flying!
- 15,132
- 415
- 1478
- 6103
- 11797
Making it real nice gator. Be a lot of fun when done.
Instigator thanked for this post
Instigator liked this post
12-28-2022, 09:38 AM #109
The Historic Photo Master
- Jan 2004
- Florida
- 38,851
- 78
- 1787
- 385
- 20583
- 5 Post(s)
...having a nice heated shop like that in ohio is the bomb...
12-28-2022, 04:06 PM #110
Looks great!!! So damn cool!!! I cannot believe the PVC rig did not work. That is crazy!
Well you have a "go cart". That is what I call my 911.
12-29-2022, 08:48 AM #111
5000 RPM
- Mar 2016
- cincinnati, ohio
- 696
- 151
- 36
- 287
- 205
Shouldn't you have the head cut for the bigger valves first so you can blend the pockets and ports when you are grinding in there???
12-29-2022, 09:47 AM #112
89LASER liked this post
12-29-2022, 12:56 PM #113
I assume they are going to put hardened valve seats in? So it will be good with unleaded gas? May as well check and see if them make some Pro Flow valves with the necked down stems for it. Springs, retainers, etc, etc. You know the drill.
How strong is the bottom end? And what kind of RPMs will it stand? I guess it is more of a torque motor?
You changing the camshaft too? That thing is going to be better than new when you are done. All new bushings, wow! How good are the brakes? It really should make a magazine article somewhere.
I run 50/50 100 low lead AV gas in my 911 because it was made to run leaded gas. I also am running 50:1 two stroke oil in it.. Let's just call it a "top end lubricant".
LOL!!!
12-29-2022, 02:33 PM #114
Paul, on paper the motor is an absolute turd!
But they run really, really well.
I am turning mine 5500 which where it starts wheezing anyhow and is factory red line.
I will turn the new motor 6500.
Racers turn them 7500+!
The experts are telling me at my level the stock cam is fine to my target rpm.
They say anything else kills bottom end for street.
I told the shop I was having a hard time wrapping my head around that one!
All new valve train (why I’m buying a bare head), roller rockers and flowed valves.
W/my playing w/ram air, the motor is taking all the air I can give it.
Which is a good sign.I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
01-21-2023, 03:58 PM #115
Rebuilding the suspension now.
Replacing all the rotted out rubber bushings with urethane versions.
Cool piece of old British engineering is their shocks.
They are cast housings full of oil w/a link/rod that actuates an internal valve.
They call them dampers.
In theory, they never wear out or need replaced.
Both of the rears are leaking and the race guys say conventional shocks are a huge upgrade so…., doing that too.
Also, just got back from picking up my donor short block to be used for the race motor.
Its a cute lil booger!I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
01-23-2023, 02:16 PM #116
My old London taxi had those lever shocks!
Great progress!
01-31-2023, 05:53 PM #117
Good news is, rear suspension is done and there were no surprises!
Yay!
Did the autopsy on the motor and good news is it’s the good block and crank like I gambled.
Bad news is, it has the early rods that are weak.
Now I decide whether to find the good MG rods and pay to shot peen and prep them or buy race rods that are way better.
By product of the parts source I found is, it’s in the home town of one one of my best buds.
Far enough away too that, it makes an overnight fun trip
We toured the Packard museum in the same town, last time there.Last edited by Instigator; 01-31-2023 at 06:52 PM.
01-31-2023, 11:22 PM #118
[QUOTE=Instigator;3376931
[/QUOTE]
I see it as a sign to install a Merc 2.5 in it. Being it's an old car everyone will think the smoke is from an old engine.
93 STV Mod VP/MERC 2.5 200
Proverbs 4:18-20
-- John F. Kennedy 1962
02-01-2023, 06:35 AM #119
02-02-2023, 03:33 PM #120
What oil do you guys run? All or most of the early 911 guys run Brad Penn because of the zinc content. I just flushed mine twice and the oil is now clear. Time to order oil. And to fill mine it is about 100 bucks not including the filter, drain washers, and gaskets for the sump.
