Results 1 to 9 of 9
    Apr 2014
    nj
    One of kind 300x induction setup for older twin ecu 3 litre
    300 x style downdraft intake complete drop on for older twin ecu 3 litre .......... I put a ton work into making these super nice , stainless bracket for fuel filter and TPS , Comes with white tip injectors and this is a plug and play upgrade for any older 3 litre . The white tip injectors were just tested , cleaned and flowed by the best in the business , FLAGSHIP MARINE FLA .
    Comes with injector print out , zero run time on injectors , only 10 minutes total run time on intake . The whole setup was tested over @ fullers back in 2014 so I would look over VST before use .
    Truly one of a kind setup , plug and play ....1900 shipped lower 48
    Attached Thumbnails Attached Thumbnails DSCN4516.JPG   DSCN4517.JPG   DSCN4518.JPG   DSCN4519.JPG   DSCN4522.JPG
    iowa
    Is this still available? I just bought a 1999 3.0 ProMax that I think this set up would work on. Not really sure what to make you for sensible offer. Let me know what you need for it and what is included. Thanks
    Apr 2014
    nj
    I have a pair of these . Whats included ? reed block to plenum and everything attached, hoses linkage ect . Ill pull them out of the boxes and take pics
    LONG ISLAND NY
    How much are you looking to get for both setups? Thanks. Sent you a pm also..
    28 K&K GHOST 225 Mercs, and loving every bit of it
    15 foot Osborne(knock off Allison) originally Evinrudejohnson's
    powered by a 110 omc, low water pickup etc.-SOLD
  5. Likes jcoop421 liked this post
    Feb 2019
    Plainview, NY
    Quote Originally Posted by frankie1995 View Post
    how much are you looking to get for both setups? Thanks. Sent you a pm also..
    money
  7. Thanks frankie1995 thanked for this post
    LONG ISLAND NY
    Quote Originally Posted by jcoop421 View Post
    money
    Thanks Justin, i figured as much... hopes and dreams don't cut it much anymore.
    Apr 2014
    nj
    one left
    Apr 2014
    nj
    A great deal of time and work went into this induction including polished one off stainless steel TPS mount and fuel filter mount . Im shocked I still have one remaining . Call or text
    609-315- two six four zero
    Apr 2014
    nj
    SOLD SOLD SOLD , its going to Texas ...........................
  1. Setup questions for and older boat
    By Colten in forum Props, Setup, and Rigging
    Last Post: 04-22-2015, 03:14 PM
  2. 2007 Bullet 21XDC, 300X SS, One Of A Kind
    By Blue Stream in forum Hulls larger than 20'
    Last Post: 02-09-2015, 09:33 PM
  3. Will new 250 xs cowl fit an older 3 litre ?
    By Skater 32 in forum Technical Discussion
    Last Post: 05-27-2010, 06:45 PM
  4. V-King with 150.....what kind of setup?
    By imq707s in forum Props, Setup, and Rigging
    Last Post: 03-05-2004, 10:22 AM
