Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
    Mar 2016
    n/a
    I didn't get your comment until I took the photos🤣😂 Thank you!
  2. #17
    Mar 2016
    n/a
    I do have another set as well but can't get to them until tomorrow. Will post them when I get the chance.
  3. #18
    Sep 2008
    louisville
    Don’t forget about the bleed lines needed . Here’s my 245
    Attached Thumbnails Attached Thumbnails 4A8F7789-0E9B-40B9-8A53-DAB9079A796A.png   7FB1BCB7-9390-48E8-9B7C-E0A2B307395A.png
  4. Thanks WOT77 thanked for this post
    Likes WOT77, rgsauger liked this post
  5. #19
    Jan 2020
    Pittsburg, Ca
    Quote Originally Posted by David View Post
    I thought that the 260s and 245s had the same porting. 15 HP from changing to EFI seemed like a lot. Was it that much?
    5 to 7 petal front...dont forget that. It was not as simple as carbs vs efi and everything else the same.
    Sorry, what was I thinking yeah they all had 7 petal fronts...I guess I was thinking of promaxes with 5 petal fronts
  6. Thanks David, WOT77 thanked for this post
    Likes pkstv liked this post
  7. #20
    Mar 2016
    n/a
    Quote Originally Posted by pkstv View Post
    Thanks for pointing this out. What carbs are on this setup? Is it a kk block?
  8. #21
    Florida Keys
    245’s were 7peddle nic motors with identical porting to a 260
    '95 STV "The Blue Goose"
  9. Thanks WOT77 thanked for this post
    Likes WOT77 liked this post
  10. #22
    Florida Keys
    If he has a 260 block it won’t have bleed fittings on the cylinders. They can be installed but that’s usually more trouble than it’s worth. A better option for a carbs (or any wet-reed system like laser efi) is to connect all the bleed lines together into one line and run that back to the fuel tank. 1/8” line is sufficient. I’d recommend your “#1” set of carbs. Again, this is pretty easy to do…..your only real issue where you will have to design something is the throttle linkage. And efi linkage won’t work, and a carb linkage won’t fit an efi front half. If I remember right (it was a while ago) I spaced a carb throttle bracket out about 3/8” and then made a custom rod to the carbs out of 1/8 round stock.
  11. Thanks WOT77 thanked for this post
    Likes Baker343 liked this post
  12. #23
    Florida Keys
    Put #72 jets in the mains of those whm-21’s to start and you’ll be good. You’ll probably end up going down to a 70 or 68 eventually.
  13. Thanks WOT77 thanked for this post
  14. #24
    Florida Keys
    And you’re going to need a 2.5 7peddle carb intake if you don’t have one already.
  15. Thanks WOT77 thanked for this post
  16. #25
    Mar 2016
    n/a
    Thank you for all of your input Mach351! That is very helpful! I'll definitely be using your input 👍!
  1. WTB Mercury 260hp 245hp 2.5L small bearing crank
    By crescentbar in forum Parts Wanted
    Last Post: 01-19-2020, 01:03 PM
  2. 245hp carbs
    By alwayssomethin in forum Technical Discussion
    Last Post: 03-29-2009, 03:44 PM
  3. 2.5 200 efi how to get to 245hp
    By jimmyz32 in forum Technical Discussion
    Last Post: 03-03-2008, 06:59 AM
