Page 3 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 31 to 45 of 154
  1. #31
    May 2001
    Hickory NC
    5 Post(s)
    The 9 pages is too much for an every day engine, the bigger ports with smaller radius mean less ring support and more chance of bridge movement. A 5/8 or 3/4 cutter would be better. Any time you add power from porting, compression etc something has to suffer and that is generally longevity. The 9 pages was meant for race engines, I cant take full credit but had a LOT to do with them. They were also done early on before even fire cranks etc at the end we ran a lot more rpm than mentioned in those pages and not for short drag type burst.
    I also dont agree these engine are port grabbers, if they do its because of any one of a number of reasons.
  2. #32
    Jul 2008
    Key Largo, FL
    About what RPM did these motors modified to the specs in the 9 pages make the most horsepower at ?
    86 18ft Motion (Action copy)
    98 Quartershot T-3
  3. #33
    May 2001
    Hickory NC
    5 Post(s)
    Mid to High 6k range later on in the low 7k range but they had more done to them
  4. #34
    Apr 2009
    The Peoples Republic of Massachusetts
    Finally!!
    Last saturday at the NEODA end of season cookout.
    NRA Life Member
    58' Farmall Cub
    Is that your mama's boat?
    "I said I didn't have much use for one. Didn't say I didn't know how to use it."- Mathew Quigley
  5. Thanks bruzercomp81 thanked for this post
    Likes bruzercomp81, wanagofass liked this post
  6. #35
    Aug 2010
    N.Florida
    So are you saying that with an everyday performance engine you should leave the ports a little more round than mentioned?
  7. #36
    so where is the porting on a CCC compared to these?
  8. #37
    Jul 2008
    Key Largo, FL
    I know I have seen pictures of the ccc ports here somewhere. They were a lot wilder. I think Chris Carson posted them if I remember correctly.
    98 Quartershot T-3
  9. #38
    May 2001
    Hickory NC
    5 Post(s)
    Yes for lake use they should have larger radius in the corners. Ports are similar but different than a ccc as it is a larger bore than a ccc and meant to push more weight so the ports are a little lower and less compression. Ports are as wide as the block/bore will allow.
  10. #39
    Oct 2013
    Southeast Georgia
    Subscribed
    13 ft allison 75 omc
    14 ft Allison
    15 ft allison molds
    17 ft tin fisher-marine 3cyl. omc
    17' Allison ski boat
    Grand Sport w/etec
  11. #40
    Scribed also.... missed this one! Gary
  12. #41
    Aug 2009
    mpls,mn
    Well you stated anything crossflow so v-4 mod on a 15ft pacecraft race boat 7200@ 85mph gps 26 cleaver pretty good for 4cyls and was very dependable,raced it for 3 yrs untouched built 6 off them never had one blow up just my 2 cents
  13. Likes wanagofass liked this post
  14. #42
    Quote Originally Posted by racervboat View Post
    Thats very impressive!!! Which motor were you starting with (140 etc.) Thanks Gary
  15. #43
    Jun 2010
    hubertus
    Ok so sorry for just budding in and don't mean to step on anyone's toes but I have a question.
    Is there a certain point, when a crossflow v6 is jetted right, that you should not stay at full throttle for long distances for the chance or burning it up?
    I have a 1980 hydrostream vandal with a mod 200 crossflow that 90 mph in 1000 ft at 7000 rpm with a 28 et. I have not tried a bigger prop yet but am considering it. It's not like I can stay in if for super long as it is, being such a small boat but I would like to put a crossflow on a fast family boat some day.
    Thank you for any info
    Scott
    1981 Hydrostream Vandal W/ evinrude 16" gt150
  16. #44
    May 2013
    I know this thread is a bit old but I’m hoping some of you guys are still around. I’m an OMC V6 (and V4 fan), and am wondering where you should run a factory bone stock XP? And while I’m asking, what about a 1985 175 (also stock, crossflow, my baby, does 50 on a really nice 4Winns Horizon 190 at 5800 RPM with the original stainless 21 inch. Thanks….
  17. #45
    Eastern PA
    These guys are still around and I’m sure will chime in. However, I think you need to be more specific about what you mean by “where you should run”? Do you mean RPM? Timing? Also, be specific about the Year model and horsepower of this “bone stock” XP and you’ll get all the answers you need from these guys. Forkin has helped me a lot in the past and he knows what he’s talking about so maybe he will opine. Good luck.
  18. Likes upyours liked this post
