Results 16 to 27 of 27
Thread: Merc tech
10-24-2022, 10:15 AM #16
Team Member
- May 2009
- 2,298
- 706
- 136
- 918
- 523
- 7 Post(s)
You were one of the “big dogs” I was referring to when I advised against using the knockoffs.
Thread hijack…
As I prep a recently purchased 2.4/200 for duty next season, I see that it has “new” stator, base, and switch boxes. I immediately suspect that they are cheap Chinesium junk. At least that’s what I suspect. Is there a way to tell? Some kinds of labels markings, serial numbers, that kind of thing?
I was planning on just moving the known-good electrics from my 2.0/150 over to the 2.4/200. But if the “new” stuff on the 2.4 can be verified as actually OK, then I’d just as soon stick with it.
-Peter"padded wonder"
__________
the wet:
18’ Bahner bow rider, 2.4/200
the dry:
2003 bmw ///M5
and a handful of clunkers
10-24-2022, 01:02 PM #17
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,962
- 599
- 100
- 523
- 632
well i switched boxes & now have good spark all 6! Buttoned all up, hitched up, pulled it out, put the muff on, no freakin water. broken water main down the road.. cant win.
pcrussell50 thanked for this post
10-24-2022, 02:09 PM #18
Glad you're all good now
10-24-2022, 02:57 PM #19
Need an expert but I think that means the bias circuit failed in the first switch box (only one bias circuit is used) so now you're using the other one and have spark on all six... but I don't know if it's OK to run that way.
Everybody says to change both switchboxes if one fails.
pcrussell50 liked this post
10-24-2022, 03:43 PM #20
Team Member
- May 2009
- 2,298
- 706
- 136
- 918
- 523
- 7 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
10-24-2022, 04:48 PM #21
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,962
- 599
- 100
- 523
- 632
Its a no go. with the switched boxes, backfire, kicks back timing berserk. put the boxes in original position, fired right up but 2-4-6 very weak. wonder# why it wont run at all when i switched boxes? #6 is totally dead, # 4 iffy #2 good.
10-24-2022, 04:53 PM #22
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,962
- 599
- 100
- 523
- 632
10-24-2022, 04:57 PM #23
Did the trigger wires follow the coil wires in the switch over?
rgsauger liked this post
10-24-2022, 07:53 PM #24
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,962
- 599
- 100
- 523
- 632
10-24-2022, 08:12 PM #25
It definitely sounds like one bad switchbox.
I would save the $500+ and buy a dva adapter, $20. If you study the pics I posted, all pertinent test info is listed.
rgsauger thanked for this post
David - WI liked this post
10-25-2022, 05:57 AM #26
Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,353
- 10
- 266
- 32
- 734
Easy test with no equipment is move the blue and red stator wires from inside to outside on the switchbox,and vice versa.Now the stator charge coils are powering different switchboxes,if the strong spark changes sides,bad stator...if it stays on the same side,bad switchbox.
Easier yet,watch the weak spark and rev the motor to 2500-3000 and see if the spark energy returns to normal...if it does the stator has a bad low speed winding on one side...bad stator.
10-25-2022, 02:34 PM #27
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,962
- 599
- 100
- 523
- 632
I Did the stator test & trigger shows good. thanks for the post. ohms only. hey Chris, we just spoke on the phone, about that bad T P I . Art K.
Merc Tech:
By pbxcomm in forum Technical DiscussionReplies: 2Last Post: 08-24-2017, 07:49 PM -
Merc tech
By Magcat 62 in forum Technical DiscussionReplies: 0Last Post: 06-10-2016, 05:56 PM -
This just in from my Merc tech
By joed in forum General Boating DiscussionReplies: 9Last Post: 11-02-2009, 01:35 PM -
Mercury Tech: Merc 2.0 tech ?
By warsteiner05 in forum Technical DiscussionReplies: 11Last Post: 08-15-2008, 09:32 PM
