Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
    NE Louisiana
    Spinning in and spinning out can make a difference. Never had an RPM problem, but my props for the twins are blue printed, balanced, etc.
  2. #17
    Quote Originally Posted by rgsauger View Post
    I’m number one! I’m number one! I’m number one!
    Chaz, if that’s your girlfriend, then you are a dirty old man! If that is your daughter, she must be adopted because she is a little doll!
    Or…Mrs Chaz is also a little doll and this one takes after her momma!
    Yes .. thats bouncing baby girl .. and yup, good thing she takes after her mama ..
  3. Likes rgsauger, Jim Speros liked this post
  4. #18
    Houston, TX
    From the look of that big ol’ smile, I would say that she loves her daddy too!
  5. Likes Jim Speros liked this post
  6. #19
    After a searching and fearless moral inventory of myself .. I have to admit there is tiny bit of ... "dirty ole man" in my mental make-up.
    Then they "all" call me "dad" .. Ohh well, maybe in the next life ...
  7. Likes rgsauger liked this post
  8. #20
    Houston, TX
    A searching and fearless moral inventory… I may have taken one of those once! LOL
  9. #21
    Mar 2022
    Lake Travis Texas
    I recall early non shifting gearcases turning a couple hundred more R's then right. That was because a gear was removed and it had less rotating drag.
    I don't buy shifting cases being uneven. There is something else unbalanced.
    Jim
  10. #22
    Nov 2013
    I went ahead and purchased an analog to nmea2000 module, i honestly didn't realize how ridiculously cheap they are. I've already got my data backbone ran all the way back there for my fuel flow sensors anyway, should be an easy way to verify my tach's before I do anything else. Plus it will be nice to have a number of other signals on my Garmin display if i choose to wire them.
  11. Likes David - WI liked this post
  12. #23
    Nov 2013
    Well it was a bad stator... a 2 year old OEM mercury stator with about 80 hours of use. I checked and the harness tests good, Who knows if this stator was ever any good, but of 6 cylinders i had 4 at spec (1100ohm), one double spec, and one open. Which would explain a 300rpm reduction vs the right motor.
    lesson learned, don't buy new old stock parts. That stator could have been 10 years old before I bought it. The right motor got a new one from amazon, the left ended up with a NOS from ebay. I think I saved 50 bucks, now its gone up from $332 to $440! lol
  13. Thanks David - WI thanked for this post
  14. #24
    Houston, TX
    Glad you found it
  15. #25
    Nov 2013
    Well that definitely fixed it. Got 64.1mph on the limiter, 6 or maybe 6100 rpms each, whatever the computer stops them at(the end of my tachometers range). Could probably get another pitch out of them with all 12 firing.
  16. Likes David - WI liked this post
  1. Left hand super speed master 12 spline propeller
    By Eprotzeller in forum Propellers Wanted
    Last Post: 04-13-2022, 11:56 PM
  2. Replies: 8
    Last Post: 04-03-2017, 10:41 AM
  3. Used propeller Mercury Clever 20 pitch thru hub left hand
    By Speed & Custom Marine in forum Propellers
    Last Post: 07-13-2016, 04:34 PM
  4. Replies: 6
    Last Post: 06-24-2016, 02:31 PM
  5. Left hand Propeller options???
    By rchevelle71 in forum General Boating Discussion
    Last Post: 02-25-2006, 09:16 PM
