Results 1 to 4 of 4
    Apr 2021
    Californian
    5 pedal or 7 pedal
    I have a question what is the performance difference between a 5 and 7pedal reed set up. Does it help on the top end mid or low end. Obviously your able to get more air more fuel equal more horsepower so what's the dawn fall.
    Jun 2018
    Floating around
    Seven petals make more power at the top of the RPM range and give up power in the lower range. From what I've read I can summarize and parrot the info gleaned which is; if your not spinning past 7000RPM your better off with a five, or four petal known as sportjet reeds which are closer to 7 performance but still solid down low.
  3. Likes FORBESAUTO, rgsauger, TEXAS20225 liked this post
    Sep 2006
    Key Largo, Fl
    This above
  5. Thanks LakeFever thanked for this post
    Likes FORBESAUTO, Capt.Insane-o liked this post
    Apr 2021
    Californian
    Thanks for the info I purchased a blown block for some parts a day at tear dawn I noticed it had a 7 pedal reed set up. With a brand new set of Chris Carson reeds in it. I was thinking of shaping but I like my low end power.
  1. 4 Pedal Rubber Reed Cage vs 5 Pedal Aluminium
    By cmb1998 in forum Technical Discussion
    Last Post: 09-18-2017, 02:51 PM
  2. Replies: 0
    Last Post: 04-11-2017, 09:03 PM
  3. 2.5 Fronthalf fishin Motor Question 4 pedal or 7 pedal ?
    By Germansaleen in forum Technical Discussion
    Last Post: 04-21-2012, 03:38 PM
