Results 31 to 45 of 53
  1. #31
    Oct 2018
    Flint River GA
    ...i could be mistaken, but i think BRP only makes, and has made for many years, just a 4 stroke, and a 2 stroke version of this little inline rotax engine. they were carb motors forever & nowadays they are efi. it didnt cost them a fortune to put this marketing experiment together. others will definately know more than i do regarding this one(really two) engine(s), that they produce...
    The 951 DI was the last 2 cycle engine in the PWC's & it was very problematic with the air fuel. The carbed engines were less problematic, ran great & made good power for the displacement as did the DI when it ran. The 951 didn't like water ingestion/intrusion at all which is why I say it would be a bad idea for this design. All 951's to some degree needed a lot of petting. Not even sure this is the same engine. RR
  2. #32
    Oct 2010
    Harrisburg,Pa
    Looks to me like they're dumbest idea yet.
  3. Likes David - WI, baja200merk liked this post
  4. #33
    Nov 2005
    Lake Eustis fl
    Will insurance cover it if you hit an obstacle underwater and the whole thing comes off the transom?
    Technology Under Rear Deck, T.U.R.D
  5. #34
    Sep 2017
    ontario
    Personally - I would prefer to know exactly the tech on this piece when available - meaning #1 -just how submerged
    2 stroke - 4 stroke -
    Cost and such before the accolades and the bashing .
    It does seem very similar to the Ghost system that had been next up before the exit
  6. #35
    5 Post(s)
    ...does insurance cover this issue for a regular outboard?...
  7. #36
    5 Post(s)
    ...who are the dealers to buy them & service them? have no idea...
  8. #37
    Oct 2009
    Gonzales, La
    Kelly it’s 2-stroke. The piston ports are evident in the picture. And I’d bet a steak dinner that it IS the ghost that they simply delayed a couple years and renamed.
    Regarding the engine relative to the water level, most pwc’s are like that already. There are strainers in the bilge hooked to a Venturi in the jet pump such that they are always evacuating whatever leaks in as long as the engine is running. I would imagine the engine has something like a crank driven bilge pump. As misguided as the concept is (to me, at least), the engineers at rotax have experience with this stuff and aren’t dummies.
  9. Thanks kellytheaker thanked for this post
  10. #38
    5 Post(s)
    ...as long as the engine is running...
  11. #39
    Jun 2018
    Floating around
    Low cg, less weight, BRP knows how to make wickedly powerful, clean burning and reliable two strokes. Plenty to be excited about in my eyes. Id buy a new merc 250 if the damn thing wouldnt sink my boat. Am i alone here? I dont mind the looks of it i think it would look awesome hanging off a stream
    of course maybe they come in heavy and unsuitable so we shall see
  12. #40
    The way they sealed the g2 cowls is as pathetic as this entire design.
  13. #41
    Chaz = thinkin, Welp ... if Kevin don't like it ... they're fugizzled ...
  14. Thanks baja200merk thanked for this post
    Likes baja200merk liked this post
  15. #42
    Nov 2019
    Canada
    Yes, they do have experience with Seadoos (obviously), the only difference there is that the hull is one piece and sealed from water intrusion. These would need a removable cowl of some sort for service, maning plenty of areas for water coming in. As mentioned above, the G2s were prone to water coming in.
    I mean come on guys this is only Evinrude's 1000th chance at making a decent product, this will be the time, THEY PROMISE!
    And as mentioned above, they just destroyed their delaer network, customer relations etc.
    www.InjectorService.com
    Call/Text - 204-326-0390
  16. Likes LakeFever, slowJEEP, baja200merk liked this post
  17. #43
    Oakville, ON
    What's a dealer network? Order on-line and it's delivered to your dock.
  18. #44
    5 Post(s)
    Quote Originally Posted by InjectorService View Post
    1000% agreed but it is not an Evinrude. The only thing you can see when the boat is sitting at idle is
    ROTAX
  1. BRC / Rotax /Johnson outboard ?
    By theoldwizard in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 08-14-2022, 04:50 PM
  2. Anybody a Rotax 503 Guru of Sort!
    By WillySteve in forum Technical Discussion
    Last Post: 02-13-2018, 08:34 PM
  3. BRP Rotax 2cyl 165hp
    By H2OPERF in forum Technical Discussion
    Last Post: 07-29-2017, 02:06 PM
  4. Rotax power
    By ROLF in forum Technical Discussion
    Last Post: 03-03-2010, 10:16 AM
  5. Rotax motors
    Last Post: 10-15-2007, 11:53 AM
