Results 1 to 15 of 17
    Dec 2017
    Lake Ashby, New Smyrna Beach FL
    For 2.5 guys, need help with trim
    I've pulled the powerhead for rebuild. Now I need to move the boat. Can I connect some of these wires to get the trim motor to work?
    I am reluctant to just start making connections.....
    1996 Checkmate Pulsare 2100 with a 2017 Merc 250 Pro XS
    Mar 2022
    Lake Travis Texas
    The wires from the trim motor come into the cowl under your hand in pic. Its either 2 or 3 wires. Solenoids have 3 relays have 2. Be careful with open fuel hoses.
    Anyway you can run motor 2 wire has a blue and a green. Connect to positive and negative. If it moves the wrong way reverse them.
    3 wire the black is ground blue is up. green is down. Do not reverse polarity on wire wire pump.
    I looked again it seems you must have a remote trim pump, offshore mid. The red blue and green leading forward must go to the pump. .
    Jim
    Dec 2017
    I have an offshore trim. There aren't any more wires under my hand. I see the green and blue on the starboard side.
    Dec 2017
    Quote Originally Posted by Jim Speros View Post
    Yes. So which of the 3 do I connect to battery?
    I tried blue / green to battery + / -. Nothing.
    Aug 2018
    MI
    Put power to trim pump, put power to blue wire, trim go up.
    blue = sky motor go up
    Green = grass, motor go down.
    My trim pump has a dedicated red from power, a dedicated ground. Then green signal wire from switch to solenoid # go down, and blue signal wire from switch for solenoid # go up
  6. Likes rgsauger liked this post
    Mar 2022
    Lake Travis Texas
    It all depends how boat is wired. The pump needs to have 12v and ground usually 10 gauge wires to battery. The small harness with 3 unplugged bullet connectors likely lead to pump. If pump has power and ground all that is needed is positive to blue. If nothing happens there is no ground and/or power to pump. If it only clicks there is no power to pump.
    Jim
    Mar 2022
    Lake Travis Texas
    The mid size black wire with blue tape on it may be pump ground. There should be but can't see a big black like the big red you have taped that leads to battery. Connect the 2 blacks.
    Maybe the large black is the longest laying in back of tray. The mid size black wire is the pump power size. If there is a red match i can't see it needs to go to big red with tape on it in pic.
    Jim
  9. #8
    Aug 2018
    MI
    If his pump has power he should be able to just plug the switch back into the cowl and trim up. The green blue trim wires from the switch to his ignition/boat side harness are still plugged in, but that switch won't do anything because the 3 bullets that are disconnected go to his pump. As soon as those are plugged back in his switch at helm or cowl should work.
  10. #9
    Aug 2018
    MI
    The large black long wire is his water tube for his water pressure gauge not a wire.
  11. #10
    Mar 2022
    Lake Travis Texas
    Yes, but small red in that harness usually comes for power thru 10 pin which is unplugged.
    Jim
  12. #11
    Aug 2018
    MI
    I wouldn’t be surprised if that small red lead goes to his in boat fuel pump.
  13. #12
    Minneapolis MN
    Give + from boat battery to the red wire from the switch on the cowl. Switch should work as normal then.
  14. Likes tux974 liked this post
  15. #13
    Massapequa NY
    Can’t you just turn the slot head bolt on the side of the mid and lift it manually?
  16. #14
    Mar 2022
    Lake Travis Texas
    Yes, if it was a 3 ram trim. He has a one ram with remote pump.
    Jim
  17. #15
    Sep 2008
    louisville
    I would have just pulled the lower unit off if I had planned on moving the boat . Seems like that would have been easier than screwing up the wires and possible sparking up a fire , just sayin.
  1. trim line help guys
    By tcrabtree in forum Technical Discussion
    Last Post: 03-09-2011, 12:04 AM
  2. where do i fill the trim fluid..omc guys?
    By quickonstep in forum Technical Discussion
    Last Post: 04-18-2004, 07:52 PM
  3. How Do You Guys Running Warp Speeds Have Your Trim Set Up??
    By Instigator in forum Technical Discussion
    Last Post: 02-24-2003, 06:23 PM
  4. Replies: 13
    Last Post: 07-01-2001, 12:45 PM
