				Results 196 to 210 of 281
		Thread: 1983 Vking rebuild
	05-23-2022, 10:01 AM #196
						Screaming And Flying!
 - 15,058
 - 407
 - 1450
 - 6006
 - 11665
I thought it would jump on plane. Nice... I would check the alignment of the engine as to why it leans left under power. Just a quarter of on inch can cause a lean on a light boat. Find center of pad and be sure that the bullet is exactly centered and engine is square to centerline.
				VkingMike liked this post
	05-23-2022, 10:23 AM #197
	05-23-2022, 11:47 AM #198
Looks great from the drivers seat. Ive never seen the trident scheme from that vantage point it looks like an arrow. So cool!
	05-23-2022, 03:52 PM #199
Congrats on a job well done.
Your lean to the left is probably prop torque. You might end up with the battery on the starboard side to level her out a bit.
	05-24-2022, 05:04 PM #200
Thanks everyone. So I did some measuring and the bullet or nose cone is dead center on the pad. So I'm guessing it's propeller torque and a light hull. It's not as noticeable as I trim up, but it's not ideal either. Might need to shift some weight.
It likely wasn't as pronounced before when the drivers seat was on the starboard side vs now being center steering
	05-28-2022, 03:21 PM #201
Looks great! Glad to see it back in the water.
Do you have a torque tab on the skeg? Might help with the lean.'78 Hydrostream Viking/'98 225 ProMax
	05-31-2022, 12:48 PM #202
	05-31-2022, 02:01 PM #203
	05-31-2022, 02:24 PM #204
I don't know about bondo? PC•7 thickened epoxy works well for tabs, and nose cones. A little thicker than the stuff Bob's sends out with their nose cone kit.
I'm still going to say some starboard weight shift will help.
	05-31-2022, 02:58 PM #205
Bondo will work just fine to test it. Works fine if you don't keep the boat in the water all the time (just day trips then out of the water to the trailer). Prime and paint and call it a day. Also P-17 works well from Adtech if you want to feel better about it!
1973 Viper - sold
1978 Viking - sold
1995 XB02
	06-08-2022, 12:28 PM #206
				OnPad liked this post
	06-08-2022, 12:32 PM #207
Good call. Start there and move up in small increments.
It will be like a different boat with the motor jacked up.
	06-08-2022, 01:47 PM #208
The bunny has threads on set up. Ive read its not flying to the max until your 2 1/2” above the pad. Havent tried this yet myself because i havent had a lwp on any of my streams til this one. I would just keep raising watching water pressure and be EXTREMELY cautious as you familiarize yourself with the prop you like best and inch up but by bit on speed.
Outasite has raced his stream since new and he said to make passes tweaking the height and trim until you have it good then leave it there for the days passes.Hydrostream dreamin
	06-09-2022, 11:20 AM #209
Engine height is going to have a bunch of variables. Boat weight etc. My best runs yet has been prop shaft CL 7/8" above pad. I went higher and lost bite on the prop, way more slip and less speed. But my hull is on the heavy side.
Like has been said before, start with the prop shaft CL even with the pad and work your way up.'78 Hydrostream Viking/'98 225 ProMax
				VkingMike thanked for this post
	06-09-2022, 01:37 PM #210
 - 15,058
 - 407
 - 1450
 - 6006
 - 11665
Also, you run 2.5 inches above, you will need a very good prop to take advantage of it
1978 vking rebuild
By rjdubiel in forum Fiberglass and Composites DiscussionReplies: 155Last Post: 04-30-2021, 01:35 PM -
1986 Hydrostream Venus 1983 Mercury 2.4 200 horsepower Trim Rebuild
By reel patriot in forum General Boating DiscussionReplies: 10Last Post: 12-31-2018, 05:55 AM -
1983 21 Sanger "classic" OB with Merc 225 engine and stringer transom rebuild/Resto.
By Zoomba in forum Technical DiscussionReplies: 2Last Post: 09-02-2013, 10:41 PM -
1983 Hydrostream Vking Resto - core, transom, floor
By WIPolaris in forum Fiberglass and Composites DiscussionReplies: 22Last Post: 01-20-2013, 09:46 PM -
motor rebuild omc v4 1983
By MIKE OSBORNE in forum Technical DiscussionReplies: 1Last Post: 08-22-2004, 08:32 PM
