Page 13 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 181 to 195 of 250
  1. #181
    May 2020
    So it’s been awhile since I’ve worked on the boat. I’m 95% done with the inside which I will finish but thinking about having a professional do the exterior (sanding, fairing, filling gouges, truing the bottom, whatever else needs to be done exterior and painting it). I just don’t have time for the exterior work, so my ? Is does anybody know of a reputable shop or person that you recommend that will do the work? I’m located in southern Wisconsin, I’d like to keep it fairly close to home but would go further to the right guy. Thanks.
  2. #182
    May 2020
ID:	505029Click image for larger version.
ID:	505030Click image for larger version.
ID:	505031Click image for larger version.
ID:	505032 Finally got back to doing a little work on the boat today. Somebody thought it was a good idea to fill in the pad flat with what looked to me was auto bondo. Hammer, chisel and grinder and back to the pad that’s been hidden for who knows how many years. As you can see I got some work to do on the bottom to get it back to where it deserves to be. The boat lived a very hard life that is for sure!
  3. Likes LakeFever liked this post
  4. #183
    Doesn't look much worse than mine
    May 2020
    Makes me feel a little better. Nobody can appreciate the amount of work that goes into these restores unless they’ve actually been there.
  6. Likes LakeFever liked this post
  7. #185
    Jun 2018
    Floating around
    Quote Originally Posted by Jmr1974 View Post
    ive built a lot if things and nothing has handed me my ass harder than restoring this boat im working on. Its a ton of effort, but it is also so very satisfying at the same time. When eating an elephant you do it one bite at a time. Keep going you got this
  8. #186
    May 2020
    [QUOTE=LakeFever;3343853]ive built a lot if things and nothing has handed me my ass harder than restoring this boat im working on. Its a ton of effort, but it is also so very satisfying at the same time. When eating an elephant you do it one bite at a time. Keep going you got this[/QUOTE getting that bondo of the pad put a smile on my face and motivates me to press on!
  9. Likes LakeFever liked this post
  10. #187
    Minneapolis MN
    Truer words never spoken. They're a labor of love for sure.
  11. #188
    May 2020
    Well I didn’t get as much done as I planned this extended holiday weekend but I am advancing forward.Click image for larger version.
ID:	505490Click image for larger version.
ID:	505491Click image for larger version.
ID:	505492Click image for larger version.
ID:	505493Click image for larger version.
ID:	505494in reality I only worked on the boat for about 3hrs this weekend removing the running surface white gel coat, trying to be very careful not to get carried away and go to deep. I’m going to use a small die grinder to get the sides of the strakes. Another hour or two and I’ll be ready to start fine tuning the running surface. Also picked up 2 cheap spray guns and received my duratec primer. I need to open up the tips on the spray guns…. What drill bit do I need to get them open enough? They only came with 1.4 tips or something like that. Happy Memorial Day!
  12. Likes LakeFever, Hippie459MN, 89LASER, tnelsmn liked this post
  13. #189
    May 2020
    Back working on the boat after 2 years. Probably setting a record here to finish a boat. Started last weekend on the fairing of the bottom and should be done this afternoon, every time I sand it another spot pops up. Plan is to have here under the spray gun next weekend to spray duratec primer. Click image for larger version.
    Attached Thumbnails Attached Thumbnails 659ADF6A-18C2-4F33-8B69-80D22C8F23C5.jpg
  14. Likes LakeFever, transomstand, 89LASER liked this post
  15. #190
    Jun 2018
    Floating around
    Dont feel bad JMR I'm still poking away on mine too. I dont have the time nor the zip i used to so these things take a little longer. Im enjoying this bit though, hope your still having fun with the work too
  16. #191
    May 2020
ID:	532415Click image for larger version.
ID:	532416 Here’s where I’m at so far today.I’ve got som pinhole’s to fix now that they really reveal themselves thru the duratec, I was hoping the duratec would do a better job filling them but they must be just a little to big. Directions say you can squeegee it into them on the first pass but I wasn’t brave enough to do that and leave the primer sitting in the gun. Looking back I probably had enough time before it set up to do that but I’m a rookie. Other than the damn pinholes here and there it turned out well. Only place I had pinholes was where I sanded thru the gel coat. Word to the wise don’t go thru your gel coat if you don’t have to. I know what I need to do to get rid of them but if anybody has any other tricks let me know.
  17. #192
    May 2020
ID:	532417Click image for larger version.
  18. #193
    Jun 2018
    Floating around
    You can mix cabosil in with the duratec and make a fine spot putty. Using a thin metal detail spreader ( made for spot putty available at any auto body supplier ) you can fill the pinholes very neatly without adding much to your sanding. There’s pics in my build thread of how this looks. I sanded all the gel off my hull so I has thousands of pinholes and this little trick worked great. Way better than trying to use faring putty
  19. #194
    May 2020
ID:	532438Click image for larger version.
ID:	532439Click image for larger version.
ID:	532440So here’s where I’m at now, did my running surface with gator glide. This is a 2 part deal, what you see is 4 coats of the base coat. This has to set for 72hrs then light sand and then lay down the graphite color in the picture. I’m pretty happy with what I got done today seeing as I’m sick as a dog! Long day of mixing and acetone cleaning. Probably won’t get much more done this weekend except fixing the pinholes in the primer. Other than the running surface the rest of the boat is going to be gray like mopar Gray. I’m probably going to order the paint Monday, at least enough for the bottom of the boat that’s primed. It would be nice to get something thats already shiny when it’s cured, not sure if this type of paint is out there. If anybody has suggestions let me know.
  20. #195
    May 2020
ID:	532448 Thanks for the tip. Will this stuff work the same? I have a bunch of it. Do I just mix it in with the primer until it turns to putty or do I need to add a catalyst with it also? Do I need to sand around the pinholes first or just fill them in? There’s no way to sand inside the holes.
  1. 1977 Ventura II Race Boat For Sale
    By JWTjr. in forum Hulls up to 20'
    Last Post: 09-30-2014, 04:59 PM
  2. Best workstand to build powerheads? Build? Buy?
    By Zoomba in forum Technical Discussion
    Last Post: 03-10-2014, 07:45 PM
  3. How fast?1977 ventura II
    By busa198 in forum General Boating Discussion
    Last Post: 03-01-2010, 08:04 PM
  4. Build better and Safer Build Union
    By SnakeBit in forum The Scream And Fly Lounge
    Last Post: 09-06-2008, 05:00 PM
  5. Ventura set up ?s
    By zzzman in forum Props, Setup, and Rigging
    Last Post: 11-15-2006, 07:41 PM
