Results 271 to 285 of 470
Thread: 1979 Viking build
03-24-2022, 05:39 AM #271
How sharp should the pad edge be? Should I sharpen the chine where the floor sits too?
03-24-2022, 07:47 AM #272
Screaming And Flying!
- 15,130
- 415
- 1478
- 6103
- 11792
Go about 6-8 feet fwd of the trans. Draw a triangle to the fwd point from the outside edges of the trans. This is the area you want to make as perfect as possible. This is your running surface at speed. Trailing edge is also very important as to sharpness. Look at the contact area in my pic, and you can see what I mean...
03-24-2022, 07:58 AM #273
Copy that thanks. We did make sure the pad was as near to perfect as we could before we did the big lay. The edges of the pad are now a little more rounded than the factory so I will be sharpening these I was thinking a 1/6” rounded chamfer for the edges? Or sharper?
the rear of the notch and pad are currently perfectly sharp with no radius at all. There is one more thing I’m not sure of but a pic will work better than trying to explain so I will get a pic and ask about it shortly.Hydrostream dreamin
03-24-2022, 08:09 AM #274
- 15,130
- 415
- 1478
- 6103
- 11792
I blocked my strake edges with 400 grit, Almost sharp enough to cut paper....Zero radius...
03-26-2022, 02:49 PM #275
I did mine perfectly sharp like Xstream.
03-26-2022, 05:17 PM #276
That looks perfect Tnels thanks for the pics. I’ll be delighted to have mine turn out that good. We have been blocking until our arms fall off. Haven’t been taking many photos because we don’t bring our phones in the work area it’s a dust disaster zone lol
tnelsmn liked this post
04-11-2022, 04:03 PM #277
04-12-2022, 06:24 PM #278
04-12-2022, 09:01 PM #279
Looking great! I found the longer the sanding block the better. I ended up using a 5' 2"x2" aluminum tube for my block getting everything into shape.
Tony'78 Hydrostream Viking/'98 225 ProMax
04-12-2022, 09:31 PM #280
Thanks Tony, we have a lot of hours in cutting this already. Fortunately by adding the big lays we had a lot of meat to work with and we shaped most of it with that already best we could which should save a lot of time blocking out the faring compound plus the added bonus of not needing a lot of putty coverage. We did have to round over the edges of the pad to get the 1708 down tight and this is what we rebuilt with the kitty hair. I found some great product it’s short strand fiberglass putty with carbon fiber reinforcement. This stuff is hard and tough! I made a couple of test pieces and could not break it by hand it is strong.
We have a bunch of sanding blocks I believe 3’ is the longest. Hopefully long enough if not it’s time to fire up the surface planer and make a new one. We have some guide coat to aid this process.Hydrostream dreamin
04-14-2022, 06:48 PM #281
04-19-2022, 04:49 PM #282
05-05-2022, 05:02 PM #283
05-06-2022, 07:20 PM #284
05-07-2022, 01:17 PM #285
MrBoatYard liked this post
1979 Hydrostream Viking
By nelson edens in forum Hulls up to 20'Replies: 6Last Post: 08-17-2020, 07:38 AM -
1979 Hydrostream Viking restore thread
By roadkill636 in forum Fiberglass and Composites DiscussionReplies: 379Last Post: 02-22-2020, 07:24 AM -
1979 checlmate eluder w 1979 merc 175
By DaveS8984 in forum Technical DiscussionReplies: 7Last Post: 06-10-2012, 02:28 PM -
1979 hydrostream viking setback
By brianbgboy in forum Technical DiscussionReplies: 8Last Post: 06-29-2004, 11:00 PM
