Results 1 to 13 of 13
    Jun 2020
    Toronto
    Removing Carrier from drive shaft
    I'm trying to rebuild my lower unit on my 1991 Mercury 200 hp. How do you remove the bearing carriers around the drive shaft? Is it a pry out with two screws method? I will try and attach a pic thanks.
    Jun 2009
    Bristol, Connecticut
    I never seen a blue piece like that before, should just be a steel right with 4 inside teeth for you to put a special tool in to unscrew it and then you can pull the driveshaft straight up
    Mar 2022
    Lake Travis Texas
    The water pump base broke into two pieces. The only thing holding it is the o ring and the accumulation of corrosion.
    Yes, all you can do is pry with two screw drives or the like. Be careful not to dent or damage the housing.
    You will need a new pump base.
    Jim
  4. Likes OnPad liked this post
    5 Post(s)
    Mar 2022
    Lake Travis Texas
    You can see the top of the o ring. The bore it is sitting in is beveled to compress the o ring on installation. The below is the surface the o ring seals on. They are the two surfaces to be careful not to dent. Also do not pry from bridge piece with RTV on it.
    Jim
    Jun 2009
    Ah yes thats the base of the water pump, maybe drill 2 or 4 screws into it and see if you can then pull up on it with come vice grips?
  8. Likes 25two.stroke liked this post
    Jan 2020
    Pittsburg, Ca
    Quote Originally Posted by Aaronhl View Post
    This works ^ be sure to use fat and short, like 1" #12 or 14 screws. You can also take the pinion nut off and pull the driveshaft out with the wp base. Most of the time they aren't that stuck though and you can just take it out of the top by prying
  10. Likes stoker2001 liked this post
    Jun 2020
    Toronto
    Great info guys. Thanks
    Jul 2002
    FT WORTH, TEXAS
    drain plug removed ?? take your a shop air plug in your air nozzel insert in to drain hole move your head away from lower pump part then find it when it blows out
  13. Likes OnPad, ssv1761982, rock liked this post
    Mar 2022
    Lake Travis Texas
    I have popped them out with a pressure tester too. But I'd rather use two tools then clean up stinky ass gear lube from everywhere.
    Jim
  15. Likes 25two.stroke liked this post
  16. #11
    Pekin, IL
    I love a good explosion.
    Rock
    Team Junk
  17. Likes Turtleherder, 25two.stroke liked this post
  18. #12
    Jan 2020
    Pittsburg, Ca
    Quote Originally Posted by rock View Post
    Rock
    explosion?
  19. #13
    Jul 2002
    FT WORTH, TEXAS
    it aint empty
  1. Mercury Tech: Difficulty in removing drive shaft in 2.5L lower unit
    By Liberator*21 in forum Technical Discussion
    Last Post: 08-13-2020, 04:32 AM
  2. Yamaha Tech: Removing drive shaft???
    By CSD23 in forum Technical Discussion
    Last Post: 07-15-2010, 05:42 PM
  3. Mercury Tech: Hints on removing Drive shaft retainer nut????
    By sl!ck in forum Technical Discussion
    Last Post: 06-11-2009, 11:29 PM
