Results 1 to 13 of 13
05-02-2022, 08:16 AM #1
Member
- Jun 2020
- Toronto
- 63
05-02-2022, 04:01 PM #2
I never seen a blue piece like that before, should just be a steel right with 4 inside teeth for you to put a special tool in to unscrew it and then you can pull the driveshaft straight up
05-02-2022, 06:50 PM #3
The water pump base broke into two pieces. The only thing holding it is the o ring and the accumulation of corrosion.
Yes, all you can do is pry with two screw drives or the like. Be careful not to dent or damage the housing.
You will need a new pump base.Jim
OnPad liked this post
05-02-2022, 07:30 PM #4
The Historic Photo Master
- Jan 2004
- Florida
- 38,847
- 78
- 1787
- 385
- 20575
- 5 Post(s)
05-02-2022, 07:52 PM #5
You can see the top of the o ring. The bore it is sitting in is beveled to compress the o ring on installation. The below is the surface the o ring seals on. They are the two surfaces to be careful not to dent. Also do not pry from bridge piece with RTV on it.
Jim
05-03-2022, 09:02 AM #6
Ah yes thats the base of the water pump, maybe drill 2 or 4 screws into it and see if you can then pull up on it with come vice grips?
25two.stroke liked this post
05-03-2022, 10:10 AM #7
stoker2001 liked this post
05-03-2022, 08:05 PM #8
Member
- Jun 2020
- Toronto
- 63
Great info guys. Thanks
05-06-2022, 12:43 AM #9
Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 505
drain plug removed ?? take your a shop air plug in your air nozzel insert in to drain hole move your head away from lower pump part then find it when it blows out
05-06-2022, 07:54 AM #10
I have popped them out with a pressure tester too. But I'd rather use two tools then clean up stinky ass gear lube from everywhere.
Jim
05-06-2022, 12:55 PM #11
I love a good explosion.
RockTeam Junk
05-06-2022, 04:30 PM #12
05-07-2022, 01:18 AM #13
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 505
it aint empty
Mercury Tech: Difficulty in removing drive shaft in 2.5L lower unit
By Liberator*21 in forum Technical DiscussionReplies: 6Last Post: 08-13-2020, 04:32 AM -
Yamaha Tech: Removing drive shaft???
By CSD23 in forum Technical DiscussionReplies: 4Last Post: 07-15-2010, 05:42 PM -
Mercury Tech: Hints on removing Drive shaft retainer nut????
By sl!ck in forum Technical DiscussionReplies: 1Last Post: 06-11-2009, 11:29 PM
