Results 31 to 45 of 45
04-06-2022, 12:47 AM #31
Junior Member
- Apr 2021
- Long Beach, CA
- 24
thats the 1998 data sheet... mine are 1985 models...not sure if theres a difference or not
04-06-2022, 04:36 AM #32
04-06-2022, 05:14 PM #33
So I got a little 2L that had the regulator on top and a rectifier , I know most of 9 and 16 stuff just had the rectifier. What's the advantage of both ?
04-07-2022, 10:34 AM #34
Junior Member
- Apr 2021
- Long Beach, CA
- 24
So while I was checking stuff over I noticed when I push both shifters forward it pushes one cable and pulls the other
so one engine is in reverse while the other is forward to achieve counter rotating props. Rather than having different lowers.
is this bad for the lower in reverse?
04-07-2022, 12:06 PM #35
A left hand gearcase is reconfigured internally to run it the reverse rotation. If you look in the carriers behind the propellers one is obviously different. It is more fatter farther aft. There are many differences including the prop shaft, bearings and carrier. If you run a right hand gearcase is reverse for an extended time it will fail.
Jim
04-07-2022, 12:19 PM #36
Junior Member
- Apr 2021
- Long Beach, CA
- 24
Well, I’ll be looking for a left hand lower unit I guess. Or can mine be rebuilt to spin left?
04-07-2022, 04:34 PM #37
Mercury controls pull for forward on right hand [Standard] gearcases. The side that pushes is the opposite rotation , the left hand side. I would think you presently have a left hand gearcase if the controls are set up for one. It is easy to see when you remove the prop and look in the propshaft carrier. One side will look different if you in fact presently have a left and right hand pair of gearcases.
Jim
04-07-2022, 07:09 PM #38
rgsauger liked this post
04-07-2022, 07:13 PM #39
Junior Member
- Apr 2021
- Long Beach, CA
- 24
05-02-2022, 11:08 AM #40
Junior Member
- Apr 2021
- Long Beach, CA
- 24
So I’ve since gotten the boat in the water. What a ride! The engines are running good but not perfect.
Port engine starts easy and runs great on the top end. It however doesn’t like idling in gear. Sneezes out of the exhaust and shuts off in the longer no wake zones. Not sure where to start?
starboard engine starts idles and runs beautifully. Only issue is when idling in gear it smokes a INSANE amount. It’s pretty overtaking in the boat which isn’t awesome for the pregnant wife.
both engines idle in gear at 900rpm. Both are pulling fuel from the same tank mixed at 40:1
any help is appreciated!!
05-02-2022, 12:06 PM #41
Sounds like port engine is running lean, and starboard might be rich, if it's smoking alot after it's warmed up.
Normal to smoke alot when cold.
You would be safe to run 50:1, for your wife's sake.
Probably need to go through you fuel system. Check your port side for obstructions, and your starboard side for a leaking needle. Been a few threads lately about such things.Last edited by OnPad; 05-02-2022 at 12:08 PM.
Dirt2water thanked for this post
05-02-2022, 05:03 PM #42
Junior Member
- Apr 2021
- Long Beach, CA
- 24
When you say leaking needle do you mean the float needle?
05-02-2022, 09:55 PM #43
Yes sir. You can take the airbox off, and watch each carb while idling. The problem carb should show itself.
Check out thread : Modified 150 Mariner, a few threads down. Fuel will be excessive out of the tube pictured in post 1, with a bad needle/seat, sticking/sunk or misadjusted float. This fellow also found decomposed fuel line in his carb orifices. Which could be your problem, or something similar, on your other motor.
05-02-2022, 11:19 PM #44
Junior Member
- Apr 2021
- Long Beach, CA
- 24
OnPad liked this post
05-03-2022, 06:41 AM #45
Dittos on mixing at 50:1 instead of 40:1. Unless you are turning over 6000 RPMs regularly, 50 to one is just fine. Congrats on the new baby!
ID these engines
By speedfreak2030 in forum Technical DiscussionReplies: 12Last Post: 09-21-2014, 12:52 PM -
Engines for someone new
By Deznuts3570 in forum General Boating DiscussionReplies: 30Last Post: 11-15-2010, 09:34 PM -
Where the "Black Max" engines H.O. engines?
By Stilldouble in forum Technical DiscussionReplies: 5Last Post: 05-18-2009, 12:42 AM -
Wonder what these engines could do?
By ptroy in forum The Scream And Fly LoungeReplies: 5Last Post: 09-08-2008, 04:51 PM
