Results 1 to 15 of 22
Thread: oil injection
    Apr 2022
    melbourne australia
    oil injection
    Hello everyone i will be deleting the oil injection on my 200 merc 1987mdl and need to know from people who have done this
    1-what preemix ratio will be best, 2- will any carby jetting or adjustments be required, 3-will i need to change the ignition timing? the comps on my powerhead are all130psi , also i would like to know if there are any modifications i can do to make it sound and run quicker? any help would be great thank you
    Jan 2020
    Pittsburg, Ca
    No carb jetting changes for oil injection.
    No timing changes, just get rid of the stabilizer module and set the timing per the manual.
    Lots of things make those motors quicker...it depends on how much time and money you wanna spend.
  3. Thanks hobbymad thanked for this post
    Likes rock liked this post
    If your running over 6500 to 7k for extended time 40:1, much over 7500 best go 32:1.
  5. Thanks hobbymad thanked for this post
    Houston, TX
    Yep, under 6K, 50:1. Over 6K, 40:1
    Ditch your black boxes, too
  7. Thanks hobbymad thanked for this post
    Apr 2022
    melbourne australia
    Thanks for your help Dave
    Apr 2022
    melbourne australia
    Appreciate your help thanks
    Apr 2022
    melbourne australia
    Quote Originally Posted by rgsauger View Post
    thanks very much and is there any avaliable info on removing the black boxes ? wiring etc.
    Apr 2022
    melbourne australia
    50:1
    hi im going to fit composite reed valves and will like to do any exhaust mods if anyone knows of any exhaust mods that work? thanks again
    Nov 2021
    Williams Bay, WI
    hobbymad
    I just recently removed oil injection, alarm module, and idle stabilizer on my 1984 150 black max. I researched many Scream & Fly posts, all combined in my description. Follow the link and see step 15
    https://www.screamandfly.com/showthr...ection-removal
  13. Thanks hobbymad thanked for this post
    Likes rgsauger liked this post
    Pekin, IL
    That link will give you all the info you need.
    Rock
    Team Junk
  15. Thanks hobbymad thanked for this post
    Likes 25two.stroke liked this post
  16. #11
    Houston, TX
    By the way, welcome to Scream and Fly!
  17. Thanks hobbymad thanked for this post
  18. #12
    Apr 2022
    melbourne australia
    Thank you and there’s one thing bothering me about removing the black box on port side as there is 5 or 6 wires coming out of it so what do you do with those wires ? I know everyone says get rid of the black box but do you remove the wires from cdi box and throw the black box out with all wires or do some wires need be joined somewhere?? My engine is 1997 200 black max, so far I’ve been given great information that’s helping me out but I’m very cautious about removing wiring as I don’t want cause anything to fry?
  19. #13
    Apr 2021
    sacramento
    not a whole lot you can do to add power without tearin it down and doin alot of exhaust port work and rebuild. ask me how i know,lol
  20. Thanks hobbymad thanked for this post
  21. #14
    Houston, TX
    Quote Originally Posted by hobbymad View Post
    Search "black boxes" and you'll find what to do. The only main thing to keep in mind is that there will need to be a "bias" wire connecting the two switchboxes on the Starboard side. It might already be there. If not, it has to have it when you ditch the boxes. I think it's white w/ black by memory.
  22. Thanks hobbymad thanked for this post
  23. #15
    Apr 2022
    melbourne australia
  24. Likes rgsauger liked this post
  1. Replies: 0
    Last Post: 08-08-2012, 06:38 AM
  2. Replies: 7
    Last Post: 01-28-2011, 08:21 AM
  3. How can you tell Laser injection from other 2.4 injection
    By jowens in forum Technical Discussion
    Last Post: 10-10-2009, 10:29 AM
  4. Oil injection on a 3.0L 225
    By zachp13 in forum Technical Discussion
    Last Post: 05-15-2008, 10:02 AM
  5. Direct Injection + Conventional Injection
    By David in forum Technical Discussion
    Last Post: 02-28-2006, 06:14 PM
