Results 1 to 15 of 15
    Nov 2021
    Newfoundland
    OMC Evinrude Johnson 115Hp Rebuild or Repower ? Jet Boat Fourwinns Fling
    Hi Group !
    First post new to boating other then a few sea doos long time ago and small pond boats i live in Newfoundland Canada. I was given a mid 90's Fourwinns Fling that I am trying to breath new life into over the winter, so i guess this is my winter project. (i didn't say how many winters lol) We have a cabin in central Newfoundland that is close to a big Lake so this jet boat could provide my family some fun during the summer.
    I have shared the start of this wrenching adventure in a few different places on various forums and it was recommended that i share it here
    So here it goes
    Attached Thumbnails Attached Thumbnails 21483E58-8D68-4D42-935A-F952360AABC2 - Copy.jpg
    Nov 2021
    Newfoundland
    Sooooo So the Po bought this boat and took it out and it started to fill up with water, took it in and put it on the trailer. It was left for multiple years not winterized. I found it on the side of a friends cabin with water in the motor compartment. I took the drain plug out and two years later it was given to me for free. Pulled the plugs and rolled the motor over by hand and it spit out water. I put oil in it and tried to boost it and found the starting motor full of water. Removed the flywheel tonight, put the new bearings in the hubs and reassembled but found some bad issues that might be game ending. When water was draining out of the boat it was coming out around the jet pump I thought it needed to be resealed, looked under and no intake grate hummm weird and there has been damage to the bottom of this boat that has been repaired
    Nov 2021
    Newfoundland
    I am going to take the motor out and take it apart and inspect it for damage. Inspect the hull and the jet pump. I am willing to spend a bit of money on this project but I don’t want to throw good money after bad.I will get to the bottom of this !!! If this does not want to be a boat anymore then at least it will be a floating platform with a v4 motor for a anchor
    Nov 2021
    Newfoundland
ID:	497219Click image for larger version.
    Nov 2021
    Newfoundland
    Nov 2021
    Newfoundland
    Ugh !!! ..............
    I NEED A SHOP MANUAL !!!!!
    Yep. thats a project.
  8. Likes Jon NL liked this post
  9. #8
    Nov 2021
    Newfoundland
    The block can be bored easy enough. All the internals can go in the round bin. The adapter plates to the pump cracked in the water jacket area from not winterizing them. You need to take a good look at that.
  11. #10
    Lake Coochiching, Ontario
    Welcome to the site. You are probably the first person from Newfoundland
  12. Likes Jon NL liked this post
    Nov 2021
    Newfoundland
    Thanks @David
    some updates
  14. #12
    Nov 2021
    Newfoundland
ID:	497749Click image for larger version.
ID:	497750Click image for larger version.
ID:	497751Click image for larger version.
ID:	497752Click image for larger version.
ID:	497753Click image for larger version.
ID:	497754Click image for larger version.
ID:	497756Click image for larger version.
  15. #13
    Nov 2021
    Newfoundland
ID:	497759Click image for larger version.
ID:	497760Click image for larger version.
ID:	497761Click image for larger version.
  16. #14
    There ya go, now fill the holes and put a bracket on the back
  17. #15
    The great corn desert of Iowa
    Cap’s right. Glass in a transom, glass over the hole in the bottom, put a jack plate on it and you are good to go. Way less money, less work, easier to work on, no winterizing the pump, faster in the end and you get lots of storage where that old power head was.
    1971 Sidewinder 14 SS w Johnson 90 v-4
    1959 Texas Maid Falcon w Mercury Mark 35A
    1981 Sylvan Sportster w Johnson 85 v-4
    2006 Harris pontoon with a Yamaha 90
    1969 Sunfish sailboat
  18. Likes Jon NL liked this post
  1. 13' Bullet 130 Rebuild & Repower
    By TwzteD in forum Fiberglass and Composites Discussion
    Last Post: 09-28-2020, 03:22 PM
  2. Evinrude XP200 Rebuild or Repower
    By Stoker88 in forum Props, Setup, and Rigging
    Last Post: 09-09-2020, 11:06 PM
  3. OMC Tech: 1990 JOHNSON 120 V4 Looper good choice for repower on family boat ?
    By Biggy in forum Technical Discussion
    Last Post: 09-19-2016, 12:25 AM
  4. 30' velocity rebuild/repower/reeverything
    By biohzrd in forum General Boating Discussion
    Last Post: 08-03-2010, 10:39 AM
