Results 1 to 9 of 9
Thread: Single vs Tandem Axle Trailer
10-15-2021, 01:07 PM #1
5000 RPM
- Aug 2018
- MI
- 465
- 39
- 233
- 297
Thoughts?
I have a single currently, I feel like my tandems and triples of the past rode smoother.....I don't live on the water so I tow a lot and was thinking about switching to a tandem.
Worth the $$? (I need to repaint my trailer and get new fenders as it is, so the only added cost will be extra springs and another axle).
10-15-2021, 02:38 PM #2
Loved the tandem for towing and looks but hated it for moving around in shop. Usually took off a set of tires when in shop for any length of time to make it easier to move by hand.
RockTeam Junk
10-15-2021, 03:15 PM #3
5000 RPM
- Aug 2018
- MI
- 465
- 39
- 233
- 297
10-15-2021, 04:44 PM #4
Can't forget the cutting and grinding and welding. My favorite parts.
RockTeam Junk
10-15-2021, 06:55 PM #5
6000 RPM
- Feb 2002
- Cudjoe Key FL
- 1,667
- 70
- 639
- 3965
- 5861
Tandem will give you a little piece on mind when trailering on the highway should you get a flat tire. Still have 3 and less impact on handling till you get off to the side of the road.
10-16-2021, 06:54 PM #6
Supporting Member
- Jul 2004
- Connecticut
- 6,273
- 519
- 209
- 1077
- 1131
I would agree that if you really tow a lot tandem is the way to go. I always wondered if you could put those sleds on one of the axles when in the garage to make pushing it around easier. I sometimes have to make a tight turn for my tandem and I put an large sisal rug under the axles and they will pivot the rug making it ok to turn.
10-24-2021, 08:42 AM #7
6000 RPM
- Nov 2006
- 1,757
- 18
- 182
- 86
- 784
- 45 Post(s)
04-13-2022, 12:57 PM #8
old thread but I did the same thing , I had a single blew a bearing lost the whole wheel on the interstate , it never hit the road again until I converted it to a tandem . If u convert and balance is right u wont have problem moving it around, if I hold my tongue down 2 above the ground the back tires come off the ground and can pivot to move around if need be
2003 mirage ski racer with e-tec power
sonicss33 liked this post
04-13-2022, 10:05 PM #9
WTB Tandem axle trailer
By john4utvols in forum Tow Vehicles and TrailersReplies: 2Last Post: 05-25-2016, 08:44 PM -
Tandem axle trailer
By Mirage in forum Non-Marine ItemsReplies: 0Last Post: 05-05-2015, 07:00 PM -
Tandem axle trailer set up
By stvhelm in forum General Boating DiscussionReplies: 30Last Post: 11-04-2002, 05:27 PM
