Results 1 to 11 of 11
Thread: V8 in race car
    Feb 2012
    England
    V8 in race car
    Hi All - Finally got the V8 running very well in the race car here in the UK. An 8 year project coming to fruition with lots of further potential AND OMC logo on display!!
    NE Louisiana
    Wow!!! That's bad ass!!!
  3. Thanks Hillclimber thanked for this post
    Likes powerabout liked this post
    12 Post(s)
    Badddd ass!
    I remember helping you when you started it.
    Congrats.
    Very few would stick w/it to get where you did.
    Please provide on board video of it, “RUNNING VERY GOOD”.
    And w/audio ��
    Congrats sir and good luck w/it!
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
    Sep 2008
    charlestown, ri
    curious: whats the cooling setup like? an external water pump, tank and radiator i'm assuming. any pics of it?
    Feb 2012
    England
    Hi Revenge - I have two large radiators each with a fan plus a Davies Craig variable speed water pump. HOWEVER - these do not get me to the recommended 135F max. Currently I am running 170 to 180F without any apparent problems. Was the 135F limit to prevent the crystallisation of the salt,when on the sea, blocking the waterways?
    Jul 2002
    Las Vegas, NV
    Is this water temp or heat temp readings?
    Keith-
    Sep 2008
    charlestown, ri
    i don't think the recommended temp has anything to do with salt crystals... just the temp the engineers liked to stop the rings from sticking and/or carbon to build up but 180f is a bit warm... almost enough to set the temp. alarm off. just a guess: it might be running warm because you have the exhaust blocked off (just an assumption or does it go strait down like it was on its original midsecton?) , and the warm water cannot escape fast enough. in other words its staying in the block a tad bit too long. i also believe there was a tiny relief hole that aided water to escape the rear section, in addition to the wet exhaust adapter but someone on here knows those motors way better than me!
  9. #8
    Yes the temp of a seawater cooled engine is top prevent the salt from coming out of solution and baking itself onto any surface.
    If you see an severly overheated engine you can see it.
    Thermos are 143f
    Most outboards start to lose power when close to that 140 and above.
  10. #9
    Sep 2008
    charlestown, ri
    well they need to get up to temp regardless of how they are cooled. 125-152 degrees F at the top of the heads at 900 RPM . not sure about the V8 but i can imagine its the same as the v4/v6 loopers.
  11. #10
    Quote Originally Posted by Revenge22 View Post
    sure they love heat to idle well but on the dyno cooler makes more power.
    I do run thermos in all my productions engines.
  12. #11
    Feb 2012
    England
    Keith - I have a 12 point data logger on board. Logs 8 EGT's and 4 water temperatures. 170F coming out of heads and cooled to 115F after rads. I have reversed water flow through engine, no thermostats - engine warmed to 100F before race.
  13. Likes MattGreen liked this post
  1. Replies: 7
    Last Post: 07-05-2021, 05:52 PM
  2. Help matching race engine 49ci - 61ci to 14' mono race boat
    By flip in forum Technical Discussion
    Last Post: 05-21-2013, 12:40 AM
  3. Race boat nearly hits spectators at the Sarasota Offshore race last Sunday
    By Mr. Demeanor in forum General Boating Discussion
    Last Post: 07-05-2012, 07:33 AM
  4. Forget the Formula Race Merc ... the Selva is the real F4 race motor
    By Mark75H in forum General Boating Discussion
    Last Post: 08-14-2011, 09:47 AM
  5. FBI RACE SITE ALERT!!! - Feb 11 Race is at LAKE STELLA
    By Sam Baker in forum General Boating Discussion
    Last Post: 02-03-2006, 12:50 PM
