Results 16 to 30 of 37
08-30-2021, 06:44 PM #16
The Scorpion props run about 3” higher in pitch. Really stiff. Bow lift is pretty crazy.
L.T.
08-31-2021, 05:07 AM #17
5000 RPM
- Aug 2019
- Palmharbor
- 571
- 21
- 58
- 152
No matter what prop you use wont change a thing !!! It’s the Pad !! Get a streaight edge aluminum
1x3 and I guarantee there is a 1/4 Hook in it !!6 years ago Bill @ Marine Specialty’s in Largo Fla got a little giddy it 2ft chop and delaminated some of the fwd step those boats are a ight layup we re did the transom with coosaboard nodacored the deck turned the boat over and fixed the Bottem tha boat prior to any work would only go 70 with jack plate 200 2.5 cle lower 24 chopper after the work 80 + with a 26Last edited by MrG; 08-31-2021 at 05:11 AM.
09-02-2021, 12:07 PM #18
Member
- Jun 2017
- USA/CAN
- 70
- 7
- 15
Update**
Hi everyone,
Thank you this should be the last update until i can do a cone and raise the motor approx.4" over the winter. I had it out yesterday evening with my fiance and we ended up at 83MPH with the tach showing approx.5600 rpms. I still had a bit more trim(I put the wedges in) and a bit more throttle on the pedal. Must of been a bad trophy prop i had gotten but at any rate i will not be pushing it any further until it is better setup as it is a handful at 80+ and difficult to set back down as i do not have trim on the wheel which i will need to do.
The good news with this prop is my gas mileage cruising is through the roof as we seem to be cruising in the 2100-2400 RPM range for the most part.
Thanks for all the help i will definitely be going over the bottom of the boat, recore again myself this time, setup etc. over the winter and than try again next year in the mean time just enjoy it!
David - WI thanked for this post
09-07-2021, 04:29 PM #19
Member
- Jun 2017
- USA/CAN
- 70
- 7
- 15
Update*******
No longer need to search for props, wedges, jackplates or worry about the stringer as this weekend driving back with a friend and my fiance in the back seat sleeping the transom fell off... Luckily we were going slow just cruising at 2500rpms. But needless to say the motor fell down transom ripped off and boat sunk within 30 seconds.
09-07-2021, 04:33 PM #20
Well... that explains it!
09-07-2021, 05:15 PM #21
Good grief how lucky. Yet another example of don’t run an old hull without a restoration. Did you get the motor back or is it still on the bottom of the drink?
09-07-2021, 05:34 PM #22
Member
- Jun 2017
- USA/CAN
- 70
- 7
- 15
luckily I was able to turn into shore and it was only about 7’ deep so got everything out
waste of 7 grand I paid for the transom, “core” and floor. Was the 4th day on the water since all the work was done…. I’ll post some pics when I figure out how but the new transom which now I can clearly see was fastened with deck screws to the two knees on either side…. Hard to explain until I get the pics up.
I won’t say who did the work as they are being served today or tomorrow not sure as I did not get an update on that end yet. Most upsetting part is I have about 13g into the 250xs between purchase and rebuild and the money on rigging as well 3 weeksish ago is gone now….
09-07-2021, 05:59 PM #23
The motor should be ok if it didn’t hydraulic lock. You’ll want to get the water out it as afnp tho to prevent any rust from setting it. That is crazy man. Please post pics, lots of em. In fact you might want to start a new thread about this in the fiberglass section you’ll get the most traction there with replies
58Evinrude liked this post
09-07-2021, 06:17 PM #24
Team Member
- Lake Coochiching, Ontario
- 8,486
- 43
- 406
- 671
- 2144
- 6 Post(s)
If you go on the Fastboats Canada Facebook (ugh) page and ask you can get some recommendations for repair. It’s very sad what happened to you. Do get the motor died/checked up right away.
09-07-2021, 09:15 PM #25
Very eager to see good CLEAR pics of the transom work that was done
09-07-2021, 10:44 PM #26
Screaming And Flying!
- Dec 2001
- 9,487
- 271
- 191
- 1979
Deck screws.........everyone knows ya use lag bolts.......
09-08-2021, 10:21 AM #27
Member
- Jun 2017
- USA/CAN
- 70
- 7
- 15
David - WI liked this post
09-08-2021, 10:26 AM #28
Member
- Jun 2017
- USA/CAN
- 70
- 7
- 15
09-08-2021, 10:33 AM #29
5000 RPM
- Aug 2018
- MI
- 465
- 39
- 233
- 297
Well that certainly sucks. Sorry to see your boat in that condition after you paid good money to get it re-cored.
Hope the guy owns it and gets you your money back.
09-08-2021, 11:03 AM #30
Yikes.
Your fortunate your in one piece I can only imagine how that would have gone for you if that tore off at 90mph
Looks like the inner glass was cut off, new ply was laid in onto CSM using the motor bolts to clamp the ply to the transom and then it was gel coated only on the inside instead of glass, which it should be, and structural glass not CSM. That edge filler idea for squeezing in wood core on the edges with a step to bond? Is kinda weird too. Ive seen people do the s cut or puzzle piece cuts for this but regardless that left a sheer line that was not supported on the inside of the transom where ALL the load goes under power. Crap, no matter how you slice it.
Hopefully you get your $ back and really this guy ought not to be redoing any performance hulls moving forward hes going to kill someone. That said as well I am no expert at any of this but I can say to do a right good job? Take a LOT of time and patience. I wouldn't even want to say what I would have to charge to do this properly and hope to make enough money to eat.
Let us know how it goes and what you plan to do there are many here who will help you sort out the best plan.Hydrostream dreamin
Hydrostream Vegas V-Bottom
By MUDSHARK in forum Hulls up to 20'Replies: 6Last Post: 08-23-2015, 09:19 PM -
1984 Vegas V-Bottom ?
By atclen in forum Props, Setup, and RiggingReplies: 1Last Post: 08-17-2015, 08:44 PM -
Hydrostream Vegas V bottom
By Go Time in forum General Boating DiscussionReplies: 17Last Post: 01-21-2013, 10:43 PM -
opinions of vegas v bottom
By Ryan140 in forum General Boating DiscussionReplies: 2Last Post: 03-27-2007, 09:17 AM -
Vegas's without the XT bottom
By imq707s in forum General Boating DiscussionReplies: 2Last Post: 01-30-2004, 04:06 PM
