Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
    Mar 2004
    Brooklyn Park, MN
    I hope the other 5 are good! haha.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  2. #17
    Jun 2018
    Floating around
    Yeah me too. It sucks going through this
  3. #18
    Mar 2004
    Brooklyn Park, MN
    We pulled the motor down all the way Sunday and I have top pinned pistons already so that is good. I asked the piston what happened and he said the ring broke. Well he was lying as as you can see the Pinocchio Piston was heated and stuck. I am guessing my water pump kit I installed came with china impeller!!! I am pulling the lower tonight to find out.
    Me: "What happened Pinocchio Piston?"
    Pinocchio: "Ring Broke"
Name:	Straight Pinocchio piston.jpg
    Me: "Looks like you got hot."
    Pinocchio: (says nothing and looks away....)
Name:	sidways Pinocchio piston.jpg
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  4. Likes LakeFever, DieselDood liked this post
  5. #19
    Mar 2004
    Brooklyn Park, MN
    OK. Mr Pinocchio piston may not be lying as my water pump looks really good as it only had about 15 hours on it. I could not see any issues with the water pump and gaskets were all good and intact. Maybe there was a ring failure?
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  6. #20
    Aug 2009
    mpls,mn
    It got hot and that caused the ring failure.Can't trust pinocchio he's been hittin the sauce.
  7. #21
    Mar 2004
    Brooklyn Park, MN
    I am going to look in my heads and flush those to see if there is anything in there. Nothing wrong or stuck in my water pump, water tube, adaptor plate. I did find some small pcs of plastic or rubber in the water jackets but not enough to fry a cylinder from lack of water.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  8. #22
    Apr 2020
    South Carolina
    it was a ring locator pin that caused the ring to hook on the intake port. Got very lucky to not stick under power and really do some damage. But Ignition Faults were as follows: IG1 - 6, IG2 - 0, IG3 - 1, IG4 - 0, IG5 - 5, IG6 - 2. So not many and nothing to worry about in my opinion. No Injector Faults. I was hoping the side pinned pistons would be ok for a hand full of 800 foot runs at high RPM but I was wrong.
    Were these stock 280 pistons or aftermarket?
  9. #23
    Mar 2004
    Brooklyn Park, MN
    Quote Originally Posted by Qshot1989 View Post
    Top pinned merc.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  10. #24
    Apr 2020
    South Carolina
    I was referring to the side pinned one that loosed up and grab the port causing it to almost stick in the 800ft. runs
  11. #25
    Mar 2004
    Brooklyn Park, MN
    I though they were side pinned merc pistons before we pulled the motor, but once we pulled the motor apart we saw it was a good merc top pinned set of pistons already in the motor. I think I am going to swap my water tube from 1/2 to 3/4 inch to get some added volume. Also I am going to send #4 injector out as Brucato just cleaned them that same week the piston burnt! I had about 6-7 800 foot runs turning 9K+ before this happened. All the previous 10-15 hours on this motor was max of 8200 with the ROS ECM. I just got the unlimited ECM the day before the race and tested, worked well and per the prop calculator it ran 9600 on Friday using 9% slip, 29P, 2:1 lower. Then Saturday morning I did a run right before my races started and it only did 9400 so it was hurt by my race already I think..
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  12. #26
    Apr 2020
    South Carolina
    You were running a 1/2 inch tube on a 1 piece adapter?
  13. #27
    Sep 2008
    Dow, IL \ Theodosia Mo.
    And what lower unit?
  14. #28
    Mar 2004
    Brooklyn Park, MN
    Yes, running a 1/2 inch tube all summer.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  15. #29
    Mar 2004
    Brooklyn Park, MN
    Quote Originally Posted by Erine View Post
    coned big bearing 200 case.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  1. Optimax Fuel Rail Pressure Testing, Leak Testing & Calibration
    By InjectorService in forum Technical Discussion
    Last Post: 12-22-2020, 10:44 AM
  2. Video: CRT Testing Stock F1 today! Testing modified F1 on Saturday!
    By caldwellrace in forum General Boating Discussion
    Last Post: 03-26-2020, 01:11 PM
  3. Motorola ECM
    By TEXAS20225 in forum Misc. Parts and Accessories
    Last Post: 09-28-2015, 09:30 PM
  4. Motorola ECU testing
    By JeremyLewis in forum Technical Discussion
    Last Post: 06-16-2011, 10:32 PM
  5. 280 motorola ecu
    By allison92 in forum Technical Discussion
    Last Post: 10-12-2006, 06:06 AM
