Results 1 to 4 of 4
Thread: neutral gear
    May 2001
    Brookfield,Wi
    neutral gear
    I have a questiion, a friend of mine claims that the 2000 pro max 300 did not have a neutral gear and that you either started in forward or reverse. I could swear that the motor had a neutral . your thoughts.
    You are correct:
    Jul 2002
    FT WORTH, TEXAS
    no neutral?? hmm all lowers when they leave the factory have a forward and reverse gear neutral is a state of not being in either one of those , lots of people start in gear with big horse power motas to preserve the gears by not letting them slam into place as they all turn at the same time while running only to be engaged by the dog which is spinning also
    5 Post(s)
    ...anyone got the part # for the neutral gear? asking for a friend...
  5. Likes Capt.Insane-o, NZ Sidewinder liked this post
  1. Mercury Tech: Pulling a outboard Sportmaster; should it be left in forward gear or neutral.
    By 4Speed in forum Technical Discussion
    Last Post: 11-07-2020, 01:22 AM
  2. Neutral safety????
    By need1morefoot in forum Technical Discussion
    Last Post: 06-19-2012, 08:55 AM
  3. Rpm's rev to 3k at neutral??
    By play2win in forum Technical Discussion
    Last Post: 08-09-2011, 01:42 PM
  4. Mercury Tech: 300 XS neutral switch
    By JoshF in forum Technical Discussion
    Last Post: 04-24-2010, 09:25 PM
  5. Replies: 8
    Last Post: 09-07-2008, 08:24 PM
