Results 1 to 15 of 29
    Mar 2004
    Brooklyn Park, MN
    Testing Motorola 280 ECM
    Who can test my ECM for my 280 to make sure it is working correctly?
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Sep 2017
    ontario
    Simon performance - 80 bucks plus the ship if nothing found .
    Or use a DDT for basics or run it and see if it performs . Hope this helps
  3. Likes Forkin' Crazy, rjdubiel liked this post
    Mar 2004
    Brooklyn Park, MN
    Quote Originally Posted by kellytheaker View Post
    Ran it and ran really well, till #4 gave up. I have a ddt and it passed the static auto testing
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Sep 2017
    ontario
    Just lost spark on #4 ? or burnt down no/weak compression?
    I had a problem with a coil - switched them around - still nothing . Driver in ECM burnt up from that coil . It was repairable . Dan at Simon had seen many before .
    What did your DDT show for history as far as misfires . Or problems present - usually lights the DDT face but not all parameters .
    I
    Mar 2004
    Brooklyn Park, MN
    I
    Locked up #4 tight at the end of my run and would not turn over.. By the time I was towed to the landing it turned over and actually started right away and I shut it down immediately. I did not look at the misfires but will tonight and report back on errors.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Sep 2017
    ontario
    sorry to hear - i was hoping you only meant lost #4 spark . a fuel issue? check to see what you had fuel offset at as well - while your on the DDT .
    Mar 2004
    Brooklyn Park, MN
    I had it set at +1 for fuel offset, fresh clean by brucato on the injectors a few days before the race. According to the prop calculator, 20p prop, 2:1 lower, 83 mph is 9200-9600 ish. I need to get my 10K tach working to double check, but 5% slip is 9200 and 9% slip is 9600 so I am guessing I need to up the fuel offset. I usually roll off the throttle very slow from WOT after the 800 feet. I did this time as well but it got hot and stuck. Plug is just gray, no chunks. Piston top looked good but dry and gray. I need to get some time to pull the power head and start pulling it apart and will get back with everyone. I wonder if the fuel curve is just not enough to run those high rpms as when I look at drag curves they go really fat for shutdown, not sure they could do that with the 280 Motorola box as I have been told they just remove the limiter for RPM but the fuel curve stays the same as 8200 rpm or whatever the box originally was.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  9. #8
    Mar 2004
    Brooklyn Park, MN
    it was a ring locator pin that caused the ring to hook on the intake port. Got very lucky to not stick under power and really do some damage. But Ignition Faults were as follows: IG1 - 6, IG2 - 0, IG3 - 1, IG4 - 0, IG5 - 5, IG6 - 2. So not many and nothing to worry about in my opinion. No Injector Faults. I was hoping the side pinned pistons would be ok for a hand full of 800 foot runs at high RPM but I was wrong.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  10. #9
    Jun 2018
    Floating around
    Yikes, what RPM you figure is max for the side pinned pistons?
  11. #10
    Mar 2004
    Brooklyn Park, MN
    never over 9k apparently! I knew that but was hopping 10 to 15 800 foot runs wouldn't hurt them but i was wrong! I would keep them under 8k for side pins but do not listen to me, I would search for better info on the pistons you are using. A ton load of this discussion on here over the years on every brand of piston.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  12. Thanks LakeFever thanked for this post
    Mar 2004
    Brooklyn Park, MN
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  14. #12
    Jun 2018
    Floating around
    Dang that sucks. John Marles time perhaps?
  15. #13
    Mar 2004
    Brooklyn Park, MN
    New top pinned pistons and most likely a new nic sleeve. May send the whole block for nic depending on what it looks like once I have it all torn down.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  16. #14
    Mar 2004
    Brooklyn Park, MN
    Good pistons will be for sale soon
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  17. #15
    Jun 2018
    Floating around
    Dang man. Id have been interested in those pistons but im over boring and handed the work off to my guy. hes done me right on all other engines so im trusting him to get the right parts and fit them up. Im only going for 7500 RPM so im hoping they will be ok. Im pretty sure they are gonna be Wisecos
  1. Optimax Fuel Rail Pressure Testing, Leak Testing & Calibration
    By InjectorService in forum Technical Discussion
    Last Post: 12-22-2020, 10:44 AM
  2. Video: CRT Testing Stock F1 today! Testing modified F1 on Saturday!
    By caldwellrace in forum General Boating Discussion
    Last Post: 03-26-2020, 01:11 PM
  3. Motorola ECM
    By TEXAS20225 in forum Misc. Parts and Accessories
    Last Post: 09-28-2015, 09:30 PM
  4. Motorola ECU testing
    By JeremyLewis in forum Technical Discussion
    Last Post: 06-16-2011, 10:32 PM
  5. 280 motorola ecu
    By allison92 in forum Technical Discussion
    Last Post: 10-12-2006, 06:06 AM
