Results 1 to 12 of 12
    Jul 2021
    Uk
    Fatal Mistake !! Mercury 150hp
    I made the fatal mistake of loaning my boat out to my buddy and he returned it and said he ran out of fuel and now it will start but not Rev up it bogs down !! So after checking over the basics and no joy I stripped the power head tonight and found that the top piston ring on no1 piston has broke and has smashed piston pieces into the cylinder head the bore is not too bad but obviously will need reboring and an oversized piston fitted my question is can I oversize just one piston or should I remote all 6 cylinders and replace all pistons
    thanks guys
    Dec 2001
    One piston is OK.......is it a 2.0 or 2.5 ?
  3. Likes David - WI liked this post
    Houston, TX
    Doing one cylinder is fine if the other 5 are ok. Maybe hone the five and put in fresh rings while it's apart
    Nov 2020
    New Zealand
    It's ok to lend a boat under two arrangements,
    You f...k it you fix it
    or sure you can borrow my boat, just leave your boat as security.
  6. Likes kellytheaker, sonicss33, rgsauger liked this post
    Houston, TX
    Just like lending tools........
  8. Likes Forkin' Crazy, CI STV liked this post
    May 2001
    Los Angeles Ca
  10. Likes Forkin' Crazy liked this post
  11. #7
    Jul 2021
    Uk
    Quote Originally Posted by us1 View Post
    It sounds like it lost a piston ring locator pin.
    Far worse than that buddyClick image for larger version.
  12. #8
    Dec 2001
    Nothing to see here..... move on........
  13. #9
    May 2001
    Los Angeles Ca
    Yeah, thats exactly what happens when the locator pin gets loose and the ring rotates on the piston breaking in the exhaust port,
    Quote Originally Posted by [email protected] View Post
  14. Likes David - WI, coffeeguy, Forkin' Crazy liked this post
  15. #10
    St. Amant, LA
    While I would never loan a boat to someone if you do and this happens how can you be sure it would not have happened to you anyway ? So if you are a boat loaner type do you accept the risk or the loaner take some as well......all reasons I would never loan in the first place, Either way sorry for the loss.
    22R
  16. Likes David - WI liked this post
  17. #11
    Jan 2020
    Pittsburg, Ca
    When the locator pin fails....
    One ring --> 100 little tiny sprinkles atop your piston
  18. Likes David - WI, us1 liked this post
  19. #12
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by 22R View Post
    22R
    I have a VERY short list of people I will loan my boats too. But the ones on that list are responsible and run my stuff easier then I do.. I know that if something breaks it wasn't because the did something. It would have broke on me too.
  1. 1998 mercury 175hp on a 1989 mercury 150hp midsection
    By TyElrod in forum Technical Discussion
    Last Post: 01-29-2014, 02:23 PM
  2. Evinrude E-TEC 150hp DI vs Latest Mercury 150hp 4 stroke
    By LIQUID NIRVANA in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 02-07-2013, 08:18 AM
  3. BIG Fat MERC BIG MISTAKE
    By jag3639 in forum Technical Discussion
    Last Post: 05-16-2012, 08:12 PM
  4. Mercury Tech: $315 Mistake
    By INXS in forum Technical Discussion
    Last Post: 06-01-2011, 09:15 PM
