Results 1 to 15 of 17
    Dec 2010
    Denmark
    Mercuy 2.5L broken Crankshaft
    Hi,
    Sad sad,,, day today.
    Took my merc 2.5L 260HP apart because I thought that top crank bearing was gone. It turned out to my shock that my crankshaft was broken at cylinder 3.
    Is this a common failure on theese motors, or have my luck just ran out?
    Below link to youtube show the failure.
    https://youtu.be/OaDEZl7onVw
    //// Thomas
  2. Thanks aj06bolt12r thanked for this post
    Jun 2018
    Floating around
    Plastic cage bearings... yikes sorry to see this, its not fun to break a motor. Not to many people post about broken crank here, first ive seen since joining but there are many complaints of the plasticcage bearings failing. I wonder if this is what happened first which led to crank breaking?
    Jan 2020
    Pittsburg, Ca
    Dammit
    Florida Keys
    I wouldn’t say it’s common....cranks are usually pretty tough.
    These things happen though.....
    dont forget, that crank is 20-25 years old
    '95 STV "The Blue Goose"
    Aug 2017
    Grand Cayman
    I broke the crank in my old 260, way back when, but that was due to a piston sticking in the hole. Turns out the guys I bought it from didn’t bother to tell me it had one steel sleeve in the No 2 hole, and I was making a pass when the piston in that bore stuck at about 9200 or so, snapped the rod off, windowed the block and broke the crank all in one go. When I pulled the cowl off, the flywheel was all wobbly. Took out the stator too. That was some carnage.
  7. Likes David - WI liked this post
    May 2001
    Los Angeles Ca
  9. Likes LakeFever liked this post
    Aug 2020
    Dickson, Tennessee
    Lost mine about 2 months ago. Broke crank at #6.
  11. Thanks A164 thanked for this post
  12. #8
    Dec 2010
    Denmark
    Just thinking, completly new crank costs more than i can buy a deasent 225hp optimax. hmmm. I dont know the complete history of this crank as I replased it during my initial restore of this motor 8-ish years ago. But it was in very good condition then, and the bearing surfases looks also very good now. And it is not a plastic cage brake down that is the issue, they look fine.
    Sp now the situation is eighter to find an secondhand replacement or another engine.
    Saad thoug because i like the intimidating sound of it, which just makes other to back down just for the sound.
    thanks for all the replys so far,,,,.
  13. #9
    May 2001
    Los Angeles Ca
    Jun 2018
    Floating around
    All the 2.0, 2.4, and 2.5's share the same crank aside from the two types of bearing end do they not? Cant be all that hard to dig one up
    Aug 2020
    Dickson, Tennessee
    I've been looking since I broke mine. Had a few that got my hopes up but never panned out. I used to see them all the time until I actually needed one.
  16. Likes David - WI liked this post
    Dec 2010
    Denmark
    I still have my original crank, but it was replased because the engine had been submerged. And becaues previously owner did not diamantle the engine, it suffered under salt water corosion.
    Picture her shows my original abowe, and the replacement below.
Name:	Mercury 260hp 141.jpg
  18. #13
    Jul 2012
    Lufkin, Texas
    No, there are two types of center mains, shouldered or not. 2.0 and 2.5 use the shoulders, 2.4 don't. 2.4 crank only works in 2.4. 2.0 and 2.5 will swap as long as center mains stay with block and top cap stays with crank. 260 "small bearing" cranks use the same crank end as 2.0 so top caps will swap between those, 260 cap has a retainer plate for the bearing, 2.0 does not.
    There are 7 and 9 ring non-oiler cranks, 9 ring from old fishin' 2.0's, 7 ring from 260's.
    Early cranks have shoulders on the rod journals for bottom guide rods, late don't. bottom guide rods can be used on early cranks, non-shouldered rod journal cranks have to be top guided.
    There is a lot of interchangeability but you can get in trouble if you don't know what you're doing...
    Josh Peterson
  19. Thanks LakeFever, CI STV, Smalltownbassin, kellytheaker thanked for this post
  20. #14
    Jun 2010
    Ont.Canada
    Good used cranks get snapped up pretty quick.I looked for one for a 2.0 for quite a while.Actually looked at a couple that seller said were good that ended up not being.I finally parted it out.
    If I knew it was going to last this long I would have taken better care of it.
    Chris
  21. #15
    Sep 2017
    ontario
    Thanks for the education on the cranks -
    isn't the best to just buy a promax if their reasonable vs the crank right now -
  1. Broken crankshaft
    By dtrumbower in forum Technical Discussion
    Last Post: 08-09-2020, 11:27 AM
  2. 150 mercuy
    By pppsmurf47 in forum Technical Discussion
    Last Post: 04-05-2019, 06:17 AM
  3. Broken 2.5 crankshaft
    By lift2win in forum Parts Wanted
    Last Post: 01-04-2018, 05:41 PM
  4. Mercury Broken Crankshaft
    By bigerk in forum Technical Discussion
    Last Post: 08-07-2007, 06:24 PM
  5. Broken Crankshaft - 200hp Evinrude XFlow
    By Hooty in forum Technical Discussion
    Last Post: 08-23-2002, 08:16 AM
